Results 1 to 20 of 20
Thread: why does my oil pan mating surface looks like this?
    LX User ADRIANFARINA's Avatar
    Mar 2010
    86 Hatchback , 97 TL1000S , 39 Zundapp DB200 , 68 Vespa , 79 Derbi Variant , 96 CN250
    Tel-Aviv
    Question why does my oil pan mating surface looks like this?
    I'm rebuilding the engine ..
    after removing all the RTV , this is what I found
    all these welding sfots.. and they look original..
    Re: why does my oil pan mating surface looks like this?
    looks like braces for the bolt holes to me
    Jan 2011
    89 accord DX
    omaha nebraska
    i've never taken apart my accord, but i've had other hondas with oil pans like that as well.
    i believe its factory
    If you are referring to the dimples, they are normal. Your pan gasket should be filled with lots of matching holes.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yeah, that is normal. I've never had success with aftermarket gaskets on the oil pan, valve cover & oil filter base. Had to go back & replace it with OEM gaskets.
    Nov 2002
    Ridin Dirty in New York
    those are there so you wont crush the gasket beyond belief. stick to genuine honda oil pan gaskets. everything else ive tried here leaks
    My NAPA gasket is working just fine. Make sure that you tighten it in a criss-cross fashion, dab the corners with gasket-maker and don't torque the bolts past 10 ft-lbs.
    Awaiting Activation
    Jan 2011
    1987 accord dx hatchback
    arlington wa
    i have 2 a20a1 engines and havent open them up yet wonder if there going to look like that
    kinda looks like you over cleaned it a bit, makes it look harder to seal but maybe not the issue...
    definately use Honda gasket, or at least a very high quality one that fits well without using any sealer on the long flat runs, only the block crank seal corners.
    best of luck to yaa!
    Mar 2010
    Tel-Aviv
    overclean? is this possible? hmmm..
    thats normal, I used verachem super tack sealant, this allows you to glue the gasket to the pan side, if you follow the directions, and stick the bolts through the bolt holes to line it up, while drying, it works great, this stops the gasket from shifting while you install it. you don't need sealer on the block to pan side.
    Why didn't Honda just undersize the bolt holes a little on these gaskets? That's what every other manufacturer does. Then you could screw the pan bolts into the gasket and they would hold while you lifted the pan into place. As it is, they fall out just as you are getting the pan lined up and the gasket rolls back up into the nice ball it came as. Then you curse, start over and repeat sequence 10 times.
    bonding the gasket to the pan side fixes this
    Feb 2004
    89 accord lxi
    down by the bay
    I always put the gasket on the block first. The studs hold it up fine and it stays lined up when you put the pan on.
    Quote Originally Posted by Strugglebucket View Post
    You must have used a different gasket than I did. Mine went everywhere but where I wanted it to. I finally resorted to tying the blasted thing down with twist ties to keep it in place.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I agree he has buffed the oil pan up a little too much, but kept my mouth shut on my first post..
    Rubber gaskets aren't supposed be adhered with sealants technically. There are actually gasket holders that are made of plastic that keep the gasket near the block until you put the pan on, but couldn't find a pic of it on-line.. ^^ twisty ties off bread works too! Been there, done that. lol
    Quote Originally Posted by 88Accord-DX View Post
    the stuff I use isn't really a sealer, it's more of a gasket adhesive, it does seal though, the main use for it is to hold gaskets in place during assembly, the pan to gasket gets adhesive, but the gasket to block doesn't, you want to avoid using RTV type sealant on rubber gaskets though
    Nov 2002
    rtv and sealants arent really needed for honda pan gaskets... you can put a little hondabond in the corners but very very very light coat.
    I wasn't worried about it sealing, this stuff just holds the gasket in place during installation, it's a very thin material, almost like contact cement but a different material, it's worked great every time I have had to pull the pan
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    With the way that pan looks, he needs to spread a VERY LIGHT coat of hondabond on the oil pan.
    (good input on the situation guys)
  1. 2" Roloc Surface Prep Discs
    By ArokASE88LXi in forum Classic Honda Community Chat
    Last Post: 06-19-2009, 11:39 PM
  2. Clutch disk surface area..
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 03-13-2007, 03:36 PM
  3. B20A engine mating a A20A3 tranny?
    By Forgar_88 in forum 3geez Accords
    Last Post: 04-11-2005, 09:20 PM
  4. Surface gap plugs
    By Techno in forum 3geez Accords
    Last Post: 08-25-2003, 04:49 PM
  5. Original Honda Flat-Surface Emblems!
    By Paul Aerodeck86 in forum Interior & Exterior Care
    Last Post: 05-29-2002, 02:43 PM
