Results 1 to 7 of 7
Thread: Oil leak Found.. now an even worse oil leak....
    LX User Christofur's Avatar
    Jul 2010
    85 SE-i / 1997 VW Golf
    Auburn, Washington
    ok so today i was going to change my oil adapter seal. so i drain my oil after that was done i got under my car and was looking around to see if that was even the oil leak cause there is oil all over the bottom half of my engine. as i was looking i found this....this hose is from the oil pan back into the intake
    i was thinking that this was my oil leak cause above this hose was no oil at all. so i go down to the parts store get some hose install it put oil back into my engine and start it up let it warm up. i looked under my car now there's a puddle of oil under there. i jack my car back up and start to look. its dropping from the bottom pulley.(or around there) never did this before i changed that hose.
    the question is could i have been losing pressure in my motor from the hole in that hose then when i put a new hose in the pressure was greater and now my oil pan seal is leaking?(before i did notice a little drop from that area.)
    Re: Oil leak Found.. now an even worse oil leak....
    You have awakened the PCV monster. You will now be stricken with the fire of his vengeance.
    ...um, by which I mean that the hose you replaced is the tripwire for the whole PCV system. You replace that hose and the whole mess lets go. I would guess your leak has migrated higher on the PCV circuit. Look at where the breather box seals to the block and the rubber neck that comes out the top. If it is indeed leaking from under the timing belt cover, then you are in for a basic timing belt service. Just replace all the seals under there and that should get it.
    Yes the PVC pulls vented pressure from the crankcase thru that large hose and oil separater. The actual PVC valve is above all of that hardware. Seems like your system was not functioning before and now it is.
    If oil is coming from the pulley area then check cam seal, oil pump also may need new seals. Filter adapter seal usually is the one that drips right on the exhaust pipe.
    Also just curious what oil you used?
    OT but when that pic was loading it looked like a saussage
    Jul 2010
    Auburn, Washington
    i used 10w40.
    now if its the cam seal to check that can i just take the timing belt cover off and see if there's oil inside there?
    pretty much yes, you will see oil up on that area under the cover, honestly though from what Ive seen if you have an oil leak low down on the pulley side of the motor it is the oil pump seals. It comes off about like a water pump really but you have to take off the whole timing cover so you have to remove crank pulley. You would see for sure then the nice clean oil trail and which one of those areas it is coming from.
    Be carefull, because if the oil pump seals are leaking your pressure could drop sometimes. I bought the seals from Honda about 18 buck I think it was, and just take the pump apart and replace them.
    Mmmmm.....Sausage.
  1. Think I Found The Other Oil Leak
    By HondaBoy in forum 3geez Accords
    Last Post: 05-08-2005, 08:47 AM
  2. Another Oil Leak
    By 89LxiAg in forum 3geez Accords
    Last Post: 08-02-2003, 11:33 AM
  3. i found my coolant leak but tell me this....
    By meohmy01 in forum 3geez Accords
    Last Post: 03-18-2003, 05:02 AM
  4. Found the damn leak
    By Coitis1 in forum Performance
    Last Post: 10-09-2002, 09:40 PM
  5. OK, I think I found my leak, WTF is this
    By POS carb in forum 3geez Accords
    Last Post: 08-23-2002, 10:21 AM
