Results 1 to 25 of 36
Thread: About to trash my car!!
    DX User JDMPrelude23's Avatar
    Nov 2010
    Bronx, NY
    3 Months already and my car still aint starting.. I got new spark plugs because there was no spark.. then fuel was the problem so i brought a new fuel pump and filter, and cleaned out every fuel injector and still nothing.. even changed the main EFI relay and still nothing. I also got the timing right... my CEL doesnt even come on when i put the ignition to key on.
    Anybody knows what else i should try doing before i trash it???
    Facebook me= http://www.facebook.com/#!/profile.p...00000082137883
    R.I.P.= 94 Honda Prelude SI H23a
    89 Honda Accord LX-i A20
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Re: About to trash my car!!
    Ecu
    Does it run on starting fluid at all?
    Nov 2010
    Bronx, NY
    Na i tried that.. plus i heard starting fluid on fuel injected cars are bad, they're only good for carb engines.
    Quote Originally Posted by Bglad420 View Post
    Ecu
    I would have check and find out, i dont even know where thats at or how to remove/replace it.... engine got like 60k but body has 240+k... so yea maybe the ecu could be out
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    checked the fuse? fuel pump and injector fuses and also could be a short not giving power. try these 3 first, if the is Ecu doesn't work the LED light should stay a steady light and not doesn't blink then you got a faulty ecu and need to replace. i dont know how the prelude ecu works but before you spend money check the first three i listed if already checked then replace the ecu.
    Mar 2010
    88 lxi
    lawrenceville, GA
    It should be under the seat... I think
    88 lxi:
    Sep 2009
    86 Accord LXi 5sp, 293k
    Montgomery, AL
    '86 Accord LXi Sedan my dependable daily driver w\318k. "Why yes I do have a 3GEEE!"
    Quote Originally Posted by JDMPrelude23 View Post
    Starting fluid won't do anything to a fuel injected car that it wouldn't do to a carb'd car. If you spray it in, and the car starts and runs for a few seconds on the fluid, then you know you still have fuel delivery problems.
    Nov 2010
    Bronx, NY
    Quote Originally Posted by kentwat View Post
    yea i tried this and i get no blinks, its just stays off
    Quote Originally Posted by shyboyca6 View Post
    checked the fuse? Fuel pump and injector fuses and also could be a short not giving power. Try these 3 first, if the is ecu doesn't work the led light should stay a steady light and not doesn't blink then you got a faulty ecu and need to replace. I dont know how the prelude ecu works but before you spend money check the first three i listed if already checked then replace the ecu.
    yea i tried all the fuses, replace most of them with smart fuses just to make sure, even brought a new efi main relay and still nothing... (i have an 89 lxi btw, i dont have the prelude no more)
    Quote Originally Posted by 88lxi-shortram View Post
    it should be under the seat... I think
    found it, thanks!!
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Have you checked if the bulb in the CEL is ok? If it is, sounds like your ECU is fried (or has bad connections).
    AZ
    does the car crank?
    dead white and blue
    AZ
    can't help if you don't answer?
    dead white and blue
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Check your PGM-FI light on the dashboard. Or better yet, listen for "noises" when you turn the key to ON
    A normal starnting sequence would do the following:
    When the key is turned to ON, you should hear a humming noise coming from behind you; the fuel pump pressurizes the fuel lines.
    It is not a loud sound but if you listen to it you'll hear it. That will happen for about two-three seconds at most; when the ECU senses the engine not running the fuel pump is turned off -but the fuel lines remain pressurized anyway.
    At that time, the dashboard light turns itself off and you may hear a click coming from the main relay.
    Check the ECU for codes (the code list is somewhere in the website).
    There is a littke plastic cover in the ECU's side side that points to the rear seats; remove it from the top and you will see a window.
    The LED on the other side may blink, remain off, or stay ON continuously. Whatever it does come back and tell us; count the blinks if it is indeed blinking.
    Notice that the ECU may be flashing more than one code; it will blink them in sequence separated with a short pause. Observe it for a little while and you'll pick up how it works.
    Hope it helps
    Nov 2010
    Bronx, NY
    Quote Originally Posted by Nafs Asdf View Post
    Thats what im thinking, Ima have my ECU rebuilt
    does the car crank?
    Car does crank, strong too, just doesnt turn over
    Nov 2010
    Bronx, NY
    Hope it helps
    Yea man i tried this, the light doesnt come on, the fuel pump doesnt turn on.. i even changed the EFI main relay
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    you can usually find ecus for about $30+ shipping on ebay. i think it'd be alot cheaper for you than to get it rebuilt. any ecu from an 88-89 accord will work(automatic or 5speed). sounds alot like what my car did when my ecu went out. check for moisture around it when you pull it out
    Vanilla Sky's Avatar
    1999 Penalty Box
    I'd try to find a known good ECU before dumping much money in a rebuild. I'd hate to see someone dump a tidy sum of money in something just to find out that it wasn't the problem.
    if the check engine light doesn't come on, and the ecu is doing nothing, check to make sure there is power and ground at the ecu itself, does the main relay even switch on? it's controlled by the ecu, you need to check the ecu ground, and verify power is even reaching it. I think the ecu ground is under the passenger seat, don't quote me on that. I believe the lude and the accord share the same ecu as far as the A20
    Nov 2010
    Jackson, Michigan
    the ecu ground is under the driver seat right next to the ecu. when my ecu went out my cel stayed lit no matter what. i'm not saying your ecu is def not the problem but i'd check for power and ground first
    89T's Avatar
    Apr 2004
    power should be in the fuse box under the hood.
    un-motivated!
    3GR
    AZ
    so you got new spark plugs because there was no spark, did that fix the spark or is there still no spark?
    dead white and blue
    Nov 2010
    Jackson, Michigan
    SEi User knarg's Avatar
    '04 Forester 2.5XT
    Fort Collins, CO
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    might check your ignition switch too
    If not that go to the manual and test from the no start there. Prolly take an ohmmeter and some time but you'll find it
    AZ
    it shouldn't crank or do anything if his ignition switch is dead.
    if it cranks and doesn't start and has no spark i'd lean to an ignition module in the distributor or his coil. the coil is a super common failure on these cars. so is the main relay (which he replaceD) or the fuel pump.
    but with little to no information about diagnostics done or results achieved it's pretty hard to help isolate the specific problem. i guess he should just "trash" it.
    dead white and blue
  1. Convert your 3gee to run on trash
    By coolman603 in forum Classic Honda Community Chat
    Last Post: 01-16-2011, 02:02 PM
  2. trash powered 3gee jus watch it
    By danny nr crew in forum Classic Honda Pics & Videos
    Last Post: 06-16-2009, 07:34 PM
  3. keep? trash? sell? HELP!
    By HondaManDan in forum 3geez Accords
    Last Post: 07-24-2002, 03:56 AM
