Results 1 to 13 of 13
Thread: hatch tail light gaskets
    LX User VIPER1988's Avatar
    Sep 2008
    New Market, TN
    majestic no longer carries them. where else can i get some? thanks
    Re: hatch tail light gaskets
    Honda dealer? I would say a junkyard but they're impossible to get off without tearing them after 22+ years.
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    if you cannot find them at the dealership you could always make your own.
    Sep 2008
    New Market, TN
    guess ill have to make my own. non of the dealers have them for the hatchies anymore
    I have originals that aren't torn, I may get some material later this month and make some, how soon do you need them? it's just a type of sheet foam
    My 4g taillights have started leaking again after just a few years. The 3g also leaks to a lesser degree. I find the flimsy foam gaskets to be less than perfect and also quite expensive at $15/each. I'm about to go after the 4g with a tube of silicone or RTV black. Then I will be sure it won't start leaking again in a few years.
    it depends on the material you use, anything will work as long as the thickness is correct, neoprene would be the best
    I went out there and found both gaskets, they are both in really good shape, anyone know how I would scan one and save the file for actual size? If I can figure that out, I can make a download where you can print a pattern, I don't think you could do it on a standard printer though, the gasket is longer then most paper. I would go to the UPS store and have a bunch of copies made, but someone torched our new store
    Did this ever happen? I am in need of some Gaskets for my hatch.
    I actually did go after the 4g with a tube of silicone. I threw out the old leaky gaskets and squirted up the sealing surface behind the taillight with a thick bead of silicone. The old gaskets left a pretty obvious line where the taillight sealing surface contacted. Nevertheless, I was very generous with the silicone because the sealing surface is only 1/16" wide and I didn't want to miss any of it. We've had very little rain this year but so far, they have worked great. I'll definitely be doing it to the 3g when the time comes.
    bridgewater.NS Canada
    I've seen some workout mats at canadian tire that I thought would work for making some,just haven't got chance to try it.
    May 2011
    1989 Accord Lxi Hatchback
    Antelope Valley, CA
    I made a new one from one of my existing gaskets a few months ago. Didn't see this post then. I can make a copy of the pattern from the original if you would like.
    You can get the foam material from MSC they are simple to make
  1. Replies: 14
    Last Post: 11-17-2012, 04:29 AM
  2. Replies: 0
    Last Post: 12-10-2011, 09:42 AM
  3. Map Light L.e.d. Prototype1 & Tail Light Sneak Peak!
    By BITESIZE in forum Interior & Exterior Care
    Last Post: 12-02-2006, 01:15 AM
  4. Sedan vs. Hatch Tail Lights
    By loko84hb in forum 2geez Accords
    Last Post: 03-01-2006, 07:23 AM
  5. Painting my hatch tail lights red... help?
    By jagojon3 in forum Interior & Exterior Care
    Last Post: 06-10-2003, 12:31 AM
