Results 1 to 17 of 17
Thread: losts eyeball aircleaners
    the eyeball part will come in a while, but anyway, I had built the original body of these air cleaners before, but I was never happy with the velocity stacks, and I hadn't figured out how to make the elements, I decided to take the existing bodies and change a few things around.
    I'm going to copy part of this thread from my carburetor thread, then I will b adding a bunch of new pictures. to start, this is from the SU thread.
    I had found a Datsun original air cleaner base and THOUGHT it would match my carbs, wrong!! I wanted the factory velocity stacks and mounting bases off of it, it turns out after all this work the holes didn't line up, I fixed that, but more on that in a few minutes, I have no idea what they made this air cleaner out of, but it's just sheet metal right? again wrong, I don't know if they hardened it, or it's still radioactive from WW2, but I'm having a horrible time cutting the stuff, it cuts strange, machines strange, and welds strange, It might be 409 stainless, it looks like regular steel. whatever it is, it's some tough stuff,
    this is what I started with,
    and then removed the parts I wanted
    after a lot of cutting, and grinding, sanding, cussing, etc, I ended up with two of these, since the holes don't line up, I'll turn then 90 degrees on the base plates, before welding them on, then they will get the mounting holes, and piston air passage holes drilled.
    and I end up with one of these, there are a lot more then a single weld, I just had to add one after it was blasted
    these were the original velocity stacks I had made
    this is how I formed the screen
    I'll be going into this in much more detail, I still have one more of these bastards to make. I will take a lot more pictures of all the steps during the next one
    this is now, I took a bunch of pictures of making the second air cleaner today, and the eyeball part will come in at the very end of this thread.
    second post in a few minutes
    Re: losts eyeball aircleaners
    I needed to transfer the existing holes in the air cleaner bodies first, I made these three pointed pieces, out of 10-32 bolts, then used them to find the holes in the piece of paper, once the holes were marked, I taped the paper to the piece of stainless steel, and punched the center of the three holes, I have a specific carbide scribe that I abuse as a hole marking tool, it makes a much more precise mark then a standard punch. Once I make the first marks, I can go back and make a heavier punch mark with the regular punch.
    once I drill the three holes, I can screw down the air cleaner, and mark the perimeter,
    once it's marked, I sheared off as much material as possible on the shear.
    this is the plate ready to machine the edges
    center drilling the plate
    Drilling the pilot hole
    I'm missing a picture somewhere, I have a large carbide tapered reamer, I used this to bring the hole to size.
    this is the velocity stack reamed and ready to weld.
    and welded
    I haven't drilled the holes for mounting the air cleaner yet, or the cent hole for the piston, I'm waiting until I get a proper gasket first,before doing that.
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    this is gonna be killer! i really hope you do decide to try out that supercharger setup you mentioned earlier
    wait until you see the paint done
    ^ lol... awesome
    ^ lol... awesome
    I do think I'm going to change the iris from blue to green though, needs more contrast. If anyone happens to look around the ends of my carbs, they might get a shock when they look back
    thats just nasty!!! i LOVE IT!!
    Wow!!!
    SEi User knarg's Avatar
    '04 Forester 2.5XT
    Fort Collins, CO
    Ridiculous!
    Nov 2000
    Lost,
    Can you please fabricate a perpetual motion machine for me? LOL!
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Pretty fun haha, good job.
    Andrew.
    Nov 2000
    In the post apocalyptic wasteland I want Lost to be my roommate!
    Quote Originally Posted by DBMaster View Post
    lol
    what you are looking at, is screen over foam, the foam sits against the velocity stack, it's filter foam, then the screen fits over it, and the retainer fits over the screen. the whole thing is held in by the big circlips. I'm mainly concerned about air going into the velocity stacks, if some unfiltered air leaks around the edges of the stacks, it's not going to hurt anything, the only thing using that air, are the air passages for the domes on the SU's, the diameter of the velocity stacks is smaller then the retainer, so there's space around them
    DX User reYmo's Avatar
    Jun 2011
    1st gen Accord , 1980
    Indonesia
    haha....those blood vessels are quite scary
  1. losts power steering filter
    By lostforawhile in forum Project Central
    Last Post: 04-28-2012, 11:47 PM
  2. losts wiring harness projects in the hatch
    Last Post: 01-12-2011, 06:39 AM
  3. losts wal mart spray paint pictures
    Last Post: 05-29-2007, 08:45 AM
