Results 1 to 11 of 11
Thread: Tec coil........Hitachi distributor???
    Mar 2011
    1988 Honda Accord LX
    I have a tec coil (says so on it thats how i determined this) so I naturally figured i had a tec distributor.......but I went to autozone, got a tec distributor cap and rotor, got home, put the rotor on no problem (matches the old rotor perfect), but then theres the cap......its not the same. I went back to autozone, had them get me a hitachi cap, and it fits, and matches the one on my car......wtf??
    Re: Tec coil........Hitachi distributor???
    They sometimes get their catalog numbers mixed up. It's happened to me buying wheel bearing seals. Post a pic of your dizzie and we can tell you for absolute.
    Mar 2011
    Hope thats good enough
    Nov 2000
    Yeah, that's not a TEC distributor. I just wanted to be the first to reply.
    Mar 2011
    sooooo then how do I have one of these, with a tec coil, tec rotor??
    Definitely a Hitachi. Are you sure you aren't seeing TEC on the igniter module?
    Mar 2011
    possibly? Im looking at the coil lol theres so many things on this car that im not used to dealing with, but like I said the rotor definitely matches the one I took off the car and I got a TEC rotor........
    For clarification, the coil is attached to the distributor via a plug type wire, thats the coil Im looking at, says TEC right on the side, couldnt be clearer......
    Nov 2000
    I don't want to make assumptions here, but I have never heard of a Hitachi coil on these cars. Does anyone have a Hitachi coil? It is also easily possible that TEC makes repair and replacement parts for ignition systems that are not predominantly TEC. Plenty of other companies do this; Bosch, Standard Ignition, AC Delco...
    Mar 2011
    Ok, my biggest question is.......does it matter that I have a hitachi distributor and tec everything else??? if it runs, i dont care, i just want to make sure that if I have a problem, I dont overlook something as major as this, my car did have a misfire, i replaced cap, rotor, plugs and wires, plugs and wires alone didnt fix it, still havent started it yet to see if the misfire is gone
    You're fine.
    Mar 2011
    ill get some good pics of this car when I get her runnin good and get her out of the garage, 102K old grandma car haha 4 door auto LX white with MINT burgundy interior
  1. TEC vs Hitachi Distributor
    By ekoms in forum 2geez Accords
    Last Post: 12-20-2013, 10:22 PM
  2. help! Hitachi distributor and/or module and/or a conversion
    By senor honda in forum 3geez Accords
    Last Post: 02-19-2013, 02:03 PM
  3. Hitachi Distributor mechanical advance
    By omianan in forum 3geez Accords
    Last Post: 12-10-2011, 08:21 PM
  4. TEC Distributor or Hitachi?
    By Some Guy in forum 3geez Accords
    Last Post: 10-22-2006, 04:10 PM
  5. TEC or Hitachi Distributor??
    By 01RomanSS in forum 3geez Accords
    Last Post: 04-24-2004, 04:57 PM
