Results 1 to 7 of 7
Thread: why is the 86 lude faster?
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    heres the qustion. why is a 2.o liter Prelude faster than a 2.0 liter accord? which parts are better? cam? pistons? i know the tranny has beter accel cause of low gears but i already instaled it in my car. so what should i strip from this car to be faster?
    Travis
    '85 lude
    houston
    about 400 lbs
    86 Honda Accord LXI HB 5-sp
    Central California
    According to this web site a european 86-87 Si weighs 2288lbs, but federalizing alway's adds weight, +150lbs is a safe bet.
    a us spec car should weigh 2400lbs.
    http://www.prelude-fan.de/ab.htm
    And this site say's the same car with ABS weighs 2520, same thing not a federal car.
    http://www.ludd.luth.se/users/robertb/prelude.htm
    If someone has different facts, please post a url to verify.
    Now I d
    NORTH BAY ONTARIO
    so does the motor have more power? thats all i want to know
    and i need US spec... thanks tho jim
    Travis
    '85 lude
    houston
    my 85 carb by the book is 2293.
    when i first took it to the track, i took out the spare, jack, and seat. it was 2250lbs with me in it.
    the 2gen lude Si is the EXACT same engine as the 86-87 LXi
    carotman's Avatar
    Montreal South Shore
    the cam is wilder on the prelude and the camgear has a different setting on the lude.
    Oct 2002
    '89 Prelude Si 4WS
    Gig Harbor, WA
    it may be many small factors that make the lude faster than your accords... i can't be sure, but believe the lude is a tad shorter, less exhaust piping to run, or maybe the piping is run better and allows for a better flow... could be a different design in ehxaust manifold... stuff like that... for some reason, 86-87 seemed to be the fastest years for 2nd gen ludes... also, if you have a b-series engine, you could try the tranny from the 90-91 Si ludes... b21 tranny had very short gearing...
    http://www.merlindavis.com
  1. Please Help Me Go Faster
    By Kfreder in forum Performance
    Last Post: 10-09-2007, 10:16 PM
  2. Faster
    By 4130 in forum Performance
    Last Post: 03-19-2005, 07:48 PM
  3. what to go faster
    By twin turbo chris in forum General Engine Swaps
    Last Post: 11-26-2003, 04:17 AM
  4. 1988 lxi......needs to be faster!!!
    By BoneyLoc in forum Performance
    Last Post: 08-09-2002, 06:55 PM
  5. weber lx faster than lx-i
    By hondamanlxi in forum Performance
    Last Post: 08-08-2002, 07:04 AM
