Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: 85 SEI a20 swap.
    LX User Christofur's Avatar
    Jul 2010
    85 SE-i / 1997 VW Golf
    Auburn, Washington
    Re: 85 SEI a20 swap.
    Quote Originally Posted by SZfiftyfour View Post
    Sweet ! Now you just need obd1 and turbo
    i think turbo is going to be next winter project.
    one thing i didnt do way have my heater on when i first started the motor so now i have not heat.
    is there a way to get it to work? or maybe i hooked something up wrong idk.
    Glad you got it running man! So what did you have to do to fix the sputtering?
    Also as far as the heater goes, just turn the heat on in the car, leave the radiator cap off, let the car warm up and just top up the radiator. You can also bleed it out via the bleeder valve once you get some coolant circulation.
    Jul 2010
    Auburn, Washington
    the sputtering was some bad plugs i used a pair i have laying around so they were bad i put new ones in and it worked..
    ill try that today.
    Jul 2010
    Auburn, Washington
    so my idle still bounced since the swap.. so made a block off plate.
    Ichiban's Avatar
    North of You.
    what the hell was that stupid thing on the back of the manifold? the one with all the coolant lines running to it?
    ICHIBAN!
    "Now, even more better!"
    Wasn't that an IACV of some sort? So I take it you have no high idle when cold? You just adjust the cable and you're good to go? Pretty sweet! Does it throw a code though?
    Jul 2010
    Auburn, Washington
    Yes it was an IACV it never really worked right always had an idle bounce when its warming up or even when i was driving for awhile. i tried to bleed the coolant system so many times and still did it. i really didn't feel like buy a new IACV for 80 bucks so i was like fuck it its getting deleted. idk about the code parts since my EGR valve doesn't have vacuum to it so that is throwing a code.
    i haven't checked yet to see if there's a different one.
    i don't have a high idle on cold start just have to hold my foot on the gas for a min. or two doesn't bother me really i didn't have to change the cable any. i was more annoyed with the idle always changing.
    maybe once winter hits again ill go buy a new IACV.
  1. b20a swap what parts do i need to complete the swap
    By freitos in forum JDM B18A / B20A Swap Tech
    Last Post: 02-10-2012, 06:21 PM
  2. need help with swap
    By 87AccordLXsdn in forum 3geez Accords
    Last Post: 09-16-2004, 05:08 PM
  3. need help with swap
    By 87AccordLXsdn in forum Classic Honda Community Chat
    Last Post: 09-15-2004, 04:46 PM
  4. Now that the swap is done.....
    By Tref_LXI in forum Interior & Exterior Care
    Last Post: 04-13-2003, 04:30 AM
  5. b 18 swap
    By madmod89lxi in forum Performance
    Last Post: 10-02-2002, 12:17 PM
