Results 1 to 2 of 2
Thread: check compression
    LX User bushbean's Avatar
    check compression
    What is the proper way to disable fuel and ignition?
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: check compression
    Pull the fuel pump fuse.
    I think there a fuse for spark to but not sure you could always remove the spark plug wire that goes from the coil to the dizzy
  1. compression
    Last Post: 07-02-2011, 03:38 AM
  2. low compression?
    By russ_512 in forum 3geez Accords
    Last Post: 03-19-2010, 08:40 PM
  3. compression
    By sinisterfuzzy in forum Performance
    Last Post: 09-23-2006, 07:25 AM
  4. compression
    By pip in forum Performance
    Last Post: 01-27-2004, 10:47 PM
  5. how to check compression?
    By TJ89Accord in forum 3geez Accords
    Last Post: 12-10-2003, 12:32 PM
