Results 1 to 7 of 7
Thread: Automatic from A20-A to B20-A?
    LX User DJAJ's Avatar
    Feb 2010
    1988 Honda Accord 2.0SI
    Wellington New Zealand
    Would a transmission off a 2.litre carby (A20) work on a injected 2.0SI ??
    All the cheap trannys are all off carbys
    Re: Automatic from A20-A to B20-A?
    From what I have Heard you need the Bellhousing from a B18 (1.8 DOHC CARB) Gearbox to Use a A20 Gearbox, That is for manual gears tho, never heard anything with a automatic.
    Good Luck!
    Feb 2010
    Thanks
    Feb 2010
    No one knows?
    automatics, yeah I believe you can use the B20 housing and A20 internals, but I am not sure of a confirmed hybrid yet.. see the B20 section.
    The torque converter set up is definately different Im sure of that because it is solenoid controled on the B20. Look at the hydralic schematics, I believe I saw those on the factory manual for EDM models.
    You would want to use an 89 auto if you can because they are better.
    Feb 2010
    Ok cheers
    you need to go to pick a part lower hutt ive raided like 4 b20a gearboxes there. last time there was a b18a box there but its prolly gone now
  1. 89 lxi automatic
    By mboardman in forum 3geez Accords
    Last Post: 10-08-2007, 02:11 PM
  2. automatic?
    By mastaofdisasta in forum Classic Honda Community Chat
    Last Post: 09-14-2006, 06:03 PM
  3. '89 LXi Automatic 3&4th gear gone; now what?
    By hughesjim in forum 3geez Accords
    Last Post: 03-21-2005, 06:55 PM
  4. Do you need an E-brake for automatic?
    By neoblue89lxi in forum 3geez Accords
    Last Post: 07-23-2003, 08:37 PM
  5. Replies: 1
    Last Post: 07-09-2003, 04:51 PM
