This is a small project I'm installing while I'm doing the electrical work, this is the SDC heads up L.E.D. voltage monitor. I'm going to probably pull the alternator warning bulb, remove the red filter from behind the icon, and install the L.E.D. from this in it's place. This gives you an instant status of your electrical system, it's a tri color LED. when the system voltage is normal, 12-15 volts DC it's a steady green, 11-12 volts, it's amber for caution, 10-11 volts DC, it's red for warning, when it encounters abnormal voltage, over 15 volts, the LED flashes green, when below 10 volts it flashes red. the system also cycles through the colors on start up to do a self diagnostic
under a non flashing state, the LED dims after a short period of time, to prevent glare at night. when it encounters a high or low voltage situation, it goes to full brightness. This is much better then the simple idiot light, which really tells you nothing. All it does is come on when the alternator quits, no warning, no indication of whats going on, no indication of high voltage. No advance warning of a problem, I have a voltmeter, but sometimes it's hard to notice a problem if you aren't watching it. I have a number of items that can be damaged by high voltage, including my fuel pump, my ignition box, and my Odyssey battery, . Not to mention it could damage other onboard electronics, or factory modules. We have had several members lately who have had alternator problems with high voltage doing damage
These are sold on Ebay right now for around 30 bucks, cheap insurance to protect your electrical system.
