hey all, I apologize for being such a noob but here goes nothing...
Have an '89 Accord with 77k original miles on it (bought it for $1500)and it runs great...
Only problem is that the A/C no longer blows cold.
I checked the compressor and relays, etc, and everything seems ok...
My brother, a certified Honda Tech says that I must have a leak in the A/C system. He says that the refrigerant used for my year (the now defunct R12)does not evaporate and the only way I could run out of it (causing non-cold air to be produced)is for it to leak out.
Is this true? Logic tells me that everything eventually gets used up and needs to be replaced, even R12 refrigerant. If it does not evaporate or get used up is R12 supposed to last forever??
I don't think my car's A/C has any leaks, it just ran out of R12 and needs to be recharged (either with R12 or a good substitute, don't want to mess with the R134a conversion, right now too costly.....)
Anybody out there with a similar situation with their 3G Accord??
PS..he also mentioned some type of "door" that might not be opening thus not allowing refrigerant to cool the air...
PSS..anybody have any luck with recharge kits you can buy on Ebay or other similar sites???
any and all help would be kindly appreciated...
peace all,
mike from socal
