Results 1 to 17 of 17
Thread: Another newbie here :)
    Apr 2011
    Smile Another newbie here :)
    I have a 1988 Honda Accord, that I love. I purchased it from a very nice man in NM about 2 years ago. He told me about this site, but I forgot to check it out. I'm here now, trying to find information on how to repair the car. It runs,but won't go into gear,ANY gear. I've checked the fluid,but it's full. The car has been sitting under a foot of snow for 6 months and I finally have a chance to attempt a repair
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    Re: Another newbie here :)
    Hey does it just stay in park ? And also does it have the lock on the shifter? Its a auto right?
    Mar 2011
    Welcome lelabrown!
    Enjoy this forum....it is excellent and has lots of very knowledgeable people.
    And good luck with your Accord.
    Bob
    Mar 2011
    1989 Accord Lx Sedan
    Reno
    yeah if its automatic and has that automatic shift lock you should be able to just put the key in there.
    Welcome! I suspect your selector cable has taken a vacation. Get under the car and make sure it's still connected and not broken or kinked. Again, assuming it's an auto.
    Apr 2011
    Unhappy Re: Another newbie here :)
    Oh man,
    I'm so sorry for not remembering to specify that it's 5 speed stickshift;manual tranny. I'm getting old and forget everything
    The car starts and runs,but no matter what I do with the clutch,it won't go into any of the gears. Worse yet, the only mechanical work I've done is the simple stuff;oil changes,plug/wire/rotor cap changes,fuel injection gasket changes and CV boot packing type stuff. You'd think at 37,I'd know more by now
    Apr 2006
    Prolly your pressure plate throw out bearing and clutch bro
    If your shifter flops around without engaging any gears, then it's definitely the shift selector shaft between the shifter and the transmission. If so, you can probably figure out what's wrong with it by getting under the car and looking at it. If the shifter works as normal, then you have something broken inside the transmission or a broken CV axle. In both of those cases, you would want to take it to the shop.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    DONT TRY TO START IT in gear!
    ^^^ does it flop around?
    Or does it still move into the gear positions when not running? Like when it's off can you move it through the gears?
    VV VV VV
    Check the cable on the tranny for the clutch. Have someone watch the lever to see if it moves when the clutch is pressed. If not you've found the problem. Either above the clutch pedal in the car (possibly the assembly itself ), inside the cable somewhere or like what happened to me = the very end got corroded and broke.
    But if the cable moves the lever, like stated above, it's most likely your clutch / pressure plate
    Apr 2011
    Talking Re: Another newbie here :)
    First off, let me tell you folks,a BIG ♥THANK YOU ♥
    It means alot to me that y'all are on this forum helping people like me. Before it snowed 3 feet,I remember checking the cable. When the clutch was pressed,it moved I haven't tried putting it into gear while off though.I'll try that today. There's no flopping,so I'm praying that y'all are right,that it's just a clutch & plate replacement.That was my first thought,but I don't trust myself.LOL I've been over here imagining the tranny being all screwed up in dread. NO money for that.
    I'll post an update after I check that. Thank you all so much!
    I misread the original post, so ignore my posts above. My only question is, what happens when the car is running and you try to put it in gear?
    Apr 2011
    It won't go into gear at all I'm scared to force it,and when I push a little it starts crunching,so I stop
    When and how did this start happening?
    DX User JDMPrelude23's Avatar
    Nov 2010
    Bronx, NY
    Welcome to 3geez!! Congrats on the accord
    Facebook me= http://www.facebook.com/#!/profile.p...00000082137883
    R.I.P.= 94 Honda Prelude SI H23a
    89 Honda Accord LX-i A20
    Apr 2011
    It started last October,and has been sitting since then{after I towed in to CA on a Uhaul.LOL} Basically,it was fine and after I parked it the last time,I couldn't get in into gear at all.I have been waiting for the snow to stop long enough to look at it
    You towed it to California and it wouldn't shift after that? That's a bad sign. Where in California is it that it's buried under snow?
    Honda is a nice car..i like it very much...i've got a similar problem,but now everything is fine...
  1. Newbie here
    By solorexer in forum Newbie Introductions
    Last Post: 10-12-2010, 07:38 PM
  2. Newbie 3g from FL
    By 86dxhatch in forum Newbie Introductions
    Last Post: 10-11-2010, 11:55 PM
  3. Another Newbie
    By 86lxinva in forum Newbie Introductions
    Last Post: 11-12-2005, 08:40 AM
  4. Im A Newbie Yay!!!
    By kholyfire in forum Newbie Introductions
    Last Post: 01-03-2004, 02:36 PM
  5. newbie
    By HondaBoy334 in forum Newbie Introductions
    Last Post: 12-14-2003, 03:07 PM
