Explanation: I just replaced my old keihin (For an 81 4 door, 1751CC, CA version)with one I had gotten from Pick and Pull. I had cleaned the heck out of it (24 Hr Chem dip soak and all), rebuilt it (with a NAPA kit that had MOST of the seals and diaphragms) and set all the adjustments as so:
Main Idle Mixture = 2 turns out from seated
Aux. Idle Mixture = 1 3/4 out from seated
Floats= Carb "top" held upside down (At diagonal angle), floats resting against needle valve but not compressing springs in needle valve, I.E. 38 MM for large float, 34 MM for small one.
Now, after installing the "new" carb nothing worked as it should and i've managed to fiddle with the main idle mix adjustment to the point where it runs ok. I've left the floats alone, and just barely leaned my Aux mix out. Aside from some other problems with the choke I've managed to coax a somewhat proper idle out of the beast although it could be improved: It doesn't like to idle @750ish, only around 1000 or higher. Also, when it IS idling properly, I can give it a shot of gas and when the RPM drops back down it usually just stalls, then it doesn't want to start back up unless I mostly cover the main throttle bore by hand (acting as a choke). I'm thinking it runs too rich, but I've tried leaning out the main mix and it doesn't seem to help.
More Problems: When I hit the gas, it's over-revving, when I pop the clutch to shift gears, even though I've let off the gas at the same time, the engine revs for a moment like I just "punched it". If I floor it while in gear, no problems, but if the clutch is in, or it's idling in neutral it will rev like it's an angry Ferrari and it takes a few seconds to "settle down" again.
I've checked to see if my accelerator pump is "over squirting" because it does seem to be running rich but the linkage travel is to spec (about 12 MM) and the seals and diaphragm on it are new.
Extra info: My clutch has been on the way out for a LONG time. I've been grandma shifting (a good 3-4 seconds per shift) for a LONG time because if I even come close to shifting quickly it slips. It seems a long shot, but could this have any effect on my problems?
I know I've listed about 8 million things but I'm just trying to be very comprehensive in my descriptions. I've tried looking through every darn thing I can find on here and everywhere else online I can find any info about this old Keihin (There isn't much at all) but I've had no luck, I'm frankly at wits end with this flippity frackin thing so any help is greatly appreciated!!
