Results 1 to 17 of 17
Thread: Newby with auto tranny problems
    Apr 2011
    Inherited a 89 coupe from grandson. He says the tranny will not work after it warms up. When I start it and let it sit for awhile (not really warm) it shifts into forward and rev with "normal" clunk. I haven't had it out for a road test as it is not plated. I'm wondering if I could (should) try some Sea Foam Tranny fluid in it. Oil doesn't smell burnt! I have a spare parts car with a manual trans but I'm thinking this might be a bit much for the o'le body, not that I wouldn't mind trying it! Thanks in advance. Wonderful site!!
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Newby with auto tranny problems
    Hard to tell from your description, but I'd say first things first try to flush the trans fluid. Chances are you've got 20+ year trans fluid in there. Honestly I need to do the same to mine, the clunk gets pretty annoying.
    Edit:
    By the by, where are you located? Chances are there is someone local who wouldn't mind helping you out.
    '89 SE-i Coupe
    Awaiting Garage
    Jan 2011
    89 accord DX
    omaha nebraska
    tranny is toast
    had a legend that did the same thing, and after a while it drove less and less, and one day stopped.
    now what in the world, you happen to have another 3gen accord parts car with a manual tranny...
    If you ever did this kind of thing before it isnt that bad, get a roll around stool and a good creeper if you have a concrete pad to work off of. It could be a giant THM400 and working off gravel driveway..
    Make sure the throttle controled cable to the transmission isnt froze up or binding, that can hold up a lot of shifting if it is defunked.
    he's right, us older folks still get out and work on these cars, you want the manual, the auto's are pretty much power sapping junk, it's a different car with that five speed
    Apr 2011
    I live in SW Manitoba Canada (very small town). I sure am tempted to swap the 5 speed. If I did I would swap the whole power train as the motor on 5 speed runs fine, although it does have more miles than the auto. I was planning on flushing out the old fluid but was wondering about using the Sea Foam before the the flush!! Just want to get it on road for now. Don't know if I have enough time to do the swap as golfing season is ready to start in this part of the world real soon!!!
    no sea foam for auto transmssion, you dont want to pentetrate any soft materials and make them come loose, that create more problems.
    Just a fluid change, and flush is you want I guess. but no snake oils. Just like using old type F fluid or visa versa with Dexron in the old days, you can easliy cause more problems by introducing cleaners or detergent, emulsifiers, etc.. in automatics. Nothing works better to clean than fresh fluid. Honda fluid or synthetic compatable to Honda fluid.
    Nov 2000
    I am gratified that others on this forum know what a THM400 was. My first car had one. A real record setter. Had 212,000 miles on the original unit when I sold the car. Maybe the only auto more bullet-proof than the 3G.
    Fluid and filter changes made all the difference on those old GM autos. Most people during those years never touched the transmissions.
    I think the first thing you should do is go drive it to find out exactly what it's doing. "Will not work after it warms up" is pretty open ended. It could be that it's slipping, in which case you will be swapping that manual in. Or it could merely be that it's exhibiting a strange behavior because it needs a simple adjustment but drives just fine. If that's the case, your grandson will feel bad when you tell him about it. Just tell him it was a real mess and it took you a long time and a lot of money to get fixed.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Quote Originally Posted by DBMaster View Post
    geez man! we arnt all stupid!
    turbohydromatic350 and 400 are bomb proof.
    the 700r4 not so good.
    butanyhoo
    ditch the auto and whack in the manual.
    once a honda auto starts to play up, there aint bugger all that will fix it short of a complete rebuild
    Apr 2011
    Thanks all! Guess I might have to put the golfing off for awhile!!! Will keep you posted with Pics!!
    Feb 2011
    89 Dx, 89 LXi
    New West
    Depends on how SW you are in MB, I know of an excellent shop over in Souris if you aren't up to swapping that tranny our of there (Ryan's Repair).
    In 33 years of living in the Brandon area, I don't think I was on the course much before May Long at all. Out here in BC, much different story though. Golfing in Canada in January isn't a bad thing at all!
    Nov 2000
    LOL! That's not what I meant. I guess I thought that it meant I wasn't the only one here old enough to have owned a car that had a THM400 in high school.
    Apr 2011
    Just SE of Souris a bit so will maybe talk to him. Definitely need "water balls" around here for next while!!
    Feb 2011
    89 Dx, 89 LXi
    New West
    Yeah, pretty heavy snow load when I was back home to Neepawa for the holidays and from what I have seen in the Free Press and the brandon Sun it is getting pretty wet in places. Just be glad you aren't somewhere near Emerson or anywhere north of the perimeter. Golf may be waiting for a bit (although Carberry is usually one of the first to dry out and be pretty playable early thanks to the sandhills and aquifier) this season.
    Definately give Ryan a shout, he is a good guy, does really solid work, and actually is the guy that gave me my Accord (that he was pretty surprised is still running just fine at 328,000km. Had a couple drinks with him over the holidays as well and he just smiled when I pulled up in the old gal) when I was moving out here a couple years ago.
    yeah the autos tend to go....it depends on what you want to do. i say have the 5 speed swap ready once the auto dies
    Apr 2011
    Summers over so decided to get back at this project. Drained and replace trans fluid. Took it out for a test drive. It shifts fine in all gears for about 3-4 miles then quits working "major slipping". I turn it off for 4-5 minutes then away I go again for 1-2 miles then quits again and so on and so on. In my "limited knowledge" would there be something that is causing the trans fluid to "foam" and then return to fluid state when cooled down. I had GS out and we have the 5 speed out of parts car ready to be put in but I just wanted to see if there wasn't anything "small" in auto before I tackle that. GS says he wants car back when I have the 5 speed in it. Told him to "pound sand" LOL. Thanks in advance and yes I know your all going to say put 5 speed in but, but!!!
  1. auto tranny is sad
    By skinner17 in forum 3geez Accords
    Last Post: 02-10-2010, 08:36 AM
  2. Auto tranny help
    By canadian357 in forum 3geez Accords
    Last Post: 12-22-2008, 08:36 PM
  3. 3rd Gen. Newby Questions?
    By 1986DxAccord in forum 3geez Accords
    Last Post: 10-25-2004, 08:26 PM
  4. Replies: 4
    Last Post: 12-27-2003, 08:51 PM
  5. Auto tranny problems
    By YK86 in forum 3geez Accords
    Last Post: 10-04-2002, 03:38 AM
