Results 1 to 24 of 24
Thread: Swap Related Thread (I would like the opinion of the 3geez community)
    SEi User dacantu's Avatar
    Jan 2009
    Phoenix
    Arrow Swap Related Thread (I would like the opinion of the 3geez community)
    Okay guys so I find myself in a situation where there are many paths I can take towards the final build for my Coupe.
    Ill appreciate any and all of your feedback and opinions. Each option will be highlighted in a different color
    B Series Swap
    I have now sourced more than a few parts for a B series swap for my coupe.
    - I have the COMPLETE engine (GSR head and B16 Block) with accessory's and all (AC, PS, Alternator, Dizzy, Intake manifold, etc)
    - Ive got a engine harness
    - ECU
    - Sandwhich Kit for LSVTEC or B20VTEC
    - 2 DC Integra Shift Linkages that I planned to modify to fit.
    What I would need to complete the swap is:
    - Axles
    - OBD1 Conversion
    - Mounts
    - Tranny
    H2B Swap (H22 W/B Series tranny)
    I have absolutely nothing readily available for this swap but I would love to go H only because it is directly related to the Accord and would keep the originality in a sense. Chances are I will not go this route but its always an option
    K Series Swap
    Within this option are two sub options per say.
    I would really love to be the FIRST K series 3gee to cruise the streets and I would say its equally as possible as a H2B swap is for me for ONE reason only..
    I have recently acquired a Salvage/Dismantled title 1994 GSR rolling shell for practically $190. The car has more than enough parts on it to still make my money back while still get my use out of the shell as well.
    I intend to cut out the entire engine compartment from the GSR shell in order to expand my swap options. This has been done by a few people in order to make their cars mid engine Rear Wheel Drive with a swap. However, I would like to either:
    Sub-option A: Cut out the engine compartment from my accord and swap in the one from the GSR (Assuming its possible, it could expand my options for front suspension components as well ie: camber kits, coilovers, etc) Once I cut out the engine bay from my baby theres really no turning back.
    Sub-option B: Buy a Accord Hatch and follow the very same process that Vector followed when doing his Mid Engine H swap and drop in the integra engine compartment into the rear of the car while still doing a mid engine K swap. This option sounds FUN because of the Rear Wheel Drive but kind of defeats the purpose of building my accord and I would hate to ditch my build.
    I will be parting out the rest of the GSR shell to make my money back, cutting out the engine bay, and selling whatever is left for scrap metal.
    Once that is all said and done I really do think I will be going K series and ditching the b series swap regardless of how little I have left to actually complete the swap. I would love to keep the swap going to my coupe as well but having other peoples opinion really cant hurt.
    I would like everybody's input on what route I should take and why.
    -dan
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Swap Related Thread (I would like the opinion of the 3geez community)
    where as the b16/18 are plentiful both for replacement motors and after market support, the are both high strung motors that need to be revving hard to get the best out of.
    the h22a which also has very good after market support isnt as plentiful in the usa i have been lead to believe.
    the h22a has shit loads more low end than either b motor and even the most low spec version still out hp's a b18c, and with a decent exhaust and intake will easily out torque and hp a type r b18c.
    the prob with the h22a is that its a bit bulkier than the b, but not by much.
    at the end of the day, its up to you which one you want and what you can afford.
    i'd go H22a myself, but thats just coz i've owned one, and know they are a great motor
    Mar 2010
    88 lxi
    lawrenceville, GA
    i'd do H but... b series would be alot easier to swap in my opinion. but H has alot more power and torque than B's like he said... like he said $ is your only obstacle
    88 lxi:
    Well if you had endless money I think a K Swap would be awesome, but with the cost and being the first one to attempt it sounds like a Good Future goal but less likely.
    I think H22 would be a awesome swap but for many of the same reasons with the K Series I can see it being a Goal but not very realistic.
    So I could see doing B Series, I'd love to see a B20Vtec
    AZ
    swapping in an entire engine bay would not only be time consuming, it would also be retarded.
    here's the deal if you want to go K.
    get the motor and transmission, mock it up so the axles sit level and don't bind. build mounts. replicate mounts. be a hero to the community. DONE DEAL.
    dead white and blue
    that no one will buy cause no one can afford a k-series engine let alone mounts to put one in a accord
    to teh OP, if you manage to get the h22a in (and centered properly) without having to bash the frame rails to make way for the crank pulley, pls let me know how
    AZ
    a k24 costs as much as a b18...
    http://www.hmotorsonline.com/shop/sc...age&item=30032
    the h22 will definitely need clearanced because it does in virtually every civic it goes in and i don't believe the accord would be any different.
    the point about a k is it will get cheaper and cheaper. people have said no one will ever put a k in a crx or an ef chassis and now i know several arizona cars that have them or have had them.
    i will agree that the community here is significantly poorer but having the design readily available is what it's about. just like the obd1 swap parts that angus designed, yeah not very many people bought them but now if you want them they can be had.
    cutting engine bays out to fit other motors doesn't help progress the oppurtunity for new swaps.
    dead white and blue
    ^-----this, or just take the easy route and build a b-series (i have seen b-series with all sort of ranges of power from 150WHP to 850WHP). The time, effort, and cost of swapping an entire engine bay would be WAY more then just making some mounts, and axles work. If you do plan to go with a b-swap, you need to ditch that b16 block, and swap in a Built 2.0L b-series.
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    k24 ftw. the b is played out
    Ichiban's Avatar
    North of You.
    If you want easy, buy the mounts, build a b, be done with it.
    If you want different, drop in the k, weld up mounts, match up some axles, and go.
    What are you waiting for?
    ICHIBAN!
    "Now, even more better!"
    If you want to be a hero build an unbeatable A. A20 for life mutha fuckas.
    jk although I am an A20 fan. Although Cory and I were talking about Ks yesterday.
    http://www.hmotorsonline.com/shop/sc...age&item=30015
    honestly i think B is the best right now for these cars...if i had 5k to drop a K it would not be in a 3gee...not the best for aftermarket support on suspension to go track it.(im in the same problem...the b20 i was going to drop in never worked out for me) i just need a good MPG engine now or else i would need to buy a DD if i wanted to build a bad ass car
    Nov 2010
    Jackson, Michigan
    from what i've seen our cars do not need alot of aftermarket help in the handling department. and i would def drop 3k into my 3gee; infact if i fell into that kinda money i'd build the a20 top notch and struggle putting the body and trans and everthing else together lol
    Apr 2011
    '89 Accord LX
    BC, Canada
    It sounds like you've already once decided to go B-Series. From what you've got, it sounds like you're well on your way there. I don't see any reason not to follow through with a B. After all, how could you end up disappointed afterwards. They are great engines, that's been well proven!
    Quote Originally Posted by 1813mdw View Post
    we only have k sports....but i do have to say to get something with LSD...these cars are light and dont grip good...i would do one legged burn outs all the time. the a20 differential can be swapped with a b16 one.
    Jan 2009
    Phoenix
    Okay guys I greatly appreciate your opinions. I was already pretty set on what I was thinking but figured it couldnt hurt to have everyone elses opinion.
    I would agree that the B series really can put out HIGH numbers, my only issue with the B's is that, everyone has them.
    I will be going with a K considering thats kind of what I was already set on, and I want to see what a K can do in these cars.
    Legend, my plans were never to go with a B16 block or even B16 head for that matter. You could say that I am completely against the B16 in its entirety. I got the B16 block for free and was simply stating the fact that I had a longblock if I needed one. B20V ftw.
    Messy, limited slip without a doubt. I do plan on doing some research as to which is the best performing dif to run on a K. I know Ill run into troubles with the shifter cables with the k though. We'll see how that works out.
    -dan
    AZ
    i don't think you'll run into trouble it's a matter of distance and routing, a hole-saw and welder makes the world go round. you figure out which cables reach the destination and then cut a hole. it might be a trial and error but then again this entire process will be trial and error
    dead white and blue
    Quote Originally Posted by dacantu View Post
    yup...because of the K the B has dropped down in price...a k would be cool but my guy said that i would need 8k to even put in a K....with 8k i can put a down payment for rsx or 06 civic si that already come with one
    Jan 2009
    Phoenix
    Yeah I don't expect it to be easy but it won't be impossible. First I have to drop the engine in and see where its going to sit. Then comes the fitting of everything else including the shifter cables.
    Those are nice cars but my 3gee is nicer lol jk but I wouldn't spend the amount a rsx goes for in a rsx. I'd rather just buy a s2k if I'm going to drop 12k+ on a nice rsx.
    -dan
    sorry to go off topic but a s2k is not the same as getting a k 3g.
    Jan 2009
    Phoenix
    I never said it was the same. I was pointing out that I wouldn't get an RSX because they're just not practical but for the amount I'd spend on a rsx I would put that $ towards a S2K.
    Back to topic
    -dan
    AZ
    lol @ messy's logic.
    go ahead and put that downpayment into a car that ways 3k+ lbs with no torque.
    i posted the k24 because building a k20 is retarded at best. k24's make huge torque with power adders, several builds have made 300+hp all motor. ALLLLLLL MOTORRRRRRR!
    why do you think honda put the k24 in the new 2012 Si? because they realized they could make 20% more torque at 2000 less rpm. k24's are cheap and easy to build and have a higher displacement.
    dead white and blue
    Jan 2009
    Phoenix
    There's no replacement for displacement eh? Haha. Rsx are fun but like I said, not practical for their price tag for the most part. Now if I wanted a nice daily a RSX wouldnt be terrible. But I wouldn't build one.
    -dan
    AZ
    yeah i'd definitely go s2k before anything else from honda at this point. especially since you can pick up a used one for less than 10k when people want 5k for an eg with a swap...
    dead white and blue
  1. 3GEEZ:Hard To Find and Interchangeability Thread
    By King Peetis in forum Classic Honda Community Chat
    Last Post: 01-26-2012, 04:25 PM
  2. 3geez Calendar Discussion Thread
    By 2oodoor in forum 3geez News & Site Feedback
    Last Post: 08-28-2009, 01:51 PM
  3. 3geez mugen petition thread
    By speedpenguin in forum Classic Honda Community Chat
    Last Post: 08-23-2006, 05:13 PM
  4. Props to the 3geez Community
    By 3gn86lxi in forum 3geez News & Site Feedback
    Last Post: 01-13-2005, 04:42 PM
