Ok so today I have successfully removed the auto shift linkage and replaced it with standard transmission shift linkage, pretty easy just unbolt and remove. I also was able to install the clutch pedal assembly which was a major Pain in the A. But after several breaks everything went in accordingly. So far so good I still need to get the gas/ throttle cable to complete everything inside the cock pit besides the ecu which I also have, tomorrows progress will consist of pictures of how things are coming along!! I'll keep you guys updated!
