Page 24 of 30 FirstFirst ... 14202122232425262728 ... LastLast
Results 576 to 600 of 729
Thread: gfrg88's Prelude build..
  1. #576
    89T's Avatar
    Apr 2004
    Re: gfrg88's Prelude build..
    What pistons are you looking at?
    un-motivated!
    3GR
  2. #577
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    SRP. Also thought about Probe just because I hear they're cheap and good.. or so I've read..
    -Gio
    My E85 Turbo Build
    5280FEST
  3. #578
    i paid 155 per custom pistons from weisco. they are really nice and built my pistons to my specs and they were coated sides too.
    U just ask for a 30overbore b18 piston right?
    And i love the numbers u made. I wish i coulved dynoed my old car
    Sucks she let go so soon but at least u know everything works lol. Btw pump gas or e85 on that dyno pull?
  5. #580
    LXi User hondalude86's Avatar
    Dec 2003
    1986/Honda/prelude si
    Denver Colorado
    he was running e85 that day...
    Gio, I only paid 770 shipped for my rods and pistons. Might be harder to find 83mm bore stuff, but I know that it exists. Also, if you need the number for the crazy old fart that did my engine work let me know, he wasn't to spending and was did amazing work! My crank was totally fucked, and when I got it back from him, it was insanely beautiful! He even helped me find my bearings for cheap, ACL race baby!
  6. #581
    Dec 2003
    Denver Colorado
    badass, i saw the ones that gio needs!! but they were 565 from them! fuck! plus another 365 for rods!!! ouch!
  8. #583
    89T's Avatar
    Apr 2004
    un-motivated!
    3GR
  9. #584
    A Mile High.
    I know they make them. Its just the ones I wanted I couldn't find in 83mm. I wanted to keep it under 500 for pistons. Fuck it. I'll just go with CP pistons.
    -Gio
    My E85 Turbo Build
    5280FEST
  10. #585
    A Mile High.
    So I've decided I'm going with an 84mm bore. Don't think headgasket will work. So will be ordering one from cometic.
    I'm also thinking of doing big valve conversion on head while I'm at it..
    -Gio
    My E85 Turbo Build
    5280FEST
  11. #586
    so stock b20 pistons?
    A Mile High.
    not stock, but yes. b20 pistons. flat top. which should be like 10:1, plus the .030 that's shaved off the head. should be close to 11:1?
    BUT!!! This will be put off for another month, or so. I'm picking up a CRX for the girly that needs some work... DD with some grunt to it. Already has b18b1 in it with blown headgasket. stripped, pretty damn clean. for stupid cheap, so can't pass up on it!!
    -Gio
    My E85 Turbo Build
    5280FEST
  13. #588
    cygnus x-1's Avatar
    Chicago area
    84mm will be pushing the head gasket to the limit, especially with heavy boost. Going from 83mm to 84mm gets you almost nothing in terms of compression ratio, a gain of about 0.2 points. Honestly I would say it's not worth the trouble.
    If you want to bump up the compression it would be better to mill the head. 2mm off gets you to 11:1. If you want more then weld up the chambers. Getting flat top pistons will help too. Will all that you should be able to get to 13:1 or so.
    Does Cometic even make an A20 gasket?
    SI can make the valves for you. Figure around $35 each. Combined with the above work you'll want to start worrying about valve clearance if you intend to run a high lift cam.
    C|
  14. #589
    A Mile High.
    Reason I want 84mm is because probe doesn't make an 83mm piston. I was planning on talking to SI about valves. The head is already milled .030". Cometic makes gaskets for anyone; money talks
    I'm wondering if I should get another head that's not milled? I'm worried about the p2v clearance
    -Gio
    My E85 Turbo Build
    5280FEST
  15. #590
    AZ
    i'll show you some p2v clearance.
    dead white and blue
  16. #591
    A Mile High.
    still haven't touched the damn thing
    -Gio
    My E85 Turbo Build
    5280FEST
  17. #592
    A Mile High.
    She's finally not out in a public parking lot!!! Got garaged last night. Tearing out the engine, and tearing it down to pieces to see what went wrong. I'm thinking of throwing a some stock ls rods, and type r pistons in another block while I get mine built up the ass
    -Gio
    My E85 Turbo Build
    5280FEST
  18. #593
    cygnus x-1's Avatar
    Chicago area
    You know, if you guys would just tear your cars apart and never actually drive them (like me) you wouldn't have these problems with blowing engines.
    C|
  19. #594
    ^^^Lol @ this guy ^^^
  20. #595
    A Mile High.
    lmfao. Funny. I think that's why the CRX hasn't blown on me.. I never drive the damn thing haha
    -Gio
    My E85 Turbo Build
    5280FEST
  21. #596
    Dec 2003
    Denver Colorado
    hahahaha
  22. #597
    A Mile High.
    I need an a18 block!!! Anyone have one for cheap?? just need block. nothing else.
    -Gio
    My E85 Turbo Build
    5280FEST
  23. #598
    Dec 2003
    Denver Colorado
    81mm factory b-series?
  24. #599
    A Mile High.
    ITR pistons on LS rods
    It should do good with only 10psi of boost. And I won't rev over 7k rpms this time lol
    -Gio
    My E85 Turbo Build
    5280FEST
  25. #600
    Dec 2003
    Denver Colorado
    Nice!
  1. Piter's 1987 Prelude BA2 build thread
    By piter in forum Classic Preludes
    Last Post: 02-08-2012, 03:13 AM
  2. gfrg88!!!!!!!!!
    By EX-ileAccord in forum Classic Honda Community Chat
    Last Post: 09-15-2006, 06:59 AM
  3. gfrg88 Photoshoot
    By Cheeseburger in forum Classic Honda Pics & Videos
    Last Post: 07-13-2006, 09:54 PM
