Page 12 of 30 FirstFirst ... 2891011121314151622 ... LastLast
Results 276 to 300 of 729
Thread: gfrg88's Prelude build..
  1. #276
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Re: gfrg88's Prelude build..
    I want goodies like that
    1989 Honda Accord LX-I 300K+
    Build Thread
  2. #277
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    -Gio
    My E85 Turbo Build
    5280FEST
  3. #278
    A Mile High.
    More goodies
    Install begins this sunday
    -Gio
    My E85 Turbo Build
    5280FEST
  4. #279
    pics of the car with goodies.
    89T's Avatar
    Apr 2004
    specs on the ic please..
    moving along nice.
    un-motivated!
    3GR
  6. #281
    A Mile High.
    28x7x2.5
    Don't know why I got this... still wanna get the air to water set up from frozen boost...
    -Gio
    My E85 Turbo Build
    5280FEST
  7. #282
    89T's Avatar
    Apr 2004
    28x7x2.5
    2.5 in/out?
    I need to order the rad for mine.
    un-motivated!
    3GR
  8. #283
    A Mile High.
    Yupp. 2.5 in/out, and 2.5 piping...
    Soooo some more bad news, again... When I got my head rebuilt, two of the spark plug holes weren't in great shape they said; so they repaired them using time-serts... Well last night, I went to start working on car, and decided to start by throwing on my colder plugs in, and well fuck me, the entire plug and time-serts both came out!!!!
    SOO, no, I have to buy a repair kit and fix this shit. I'm using JB weld this time since apparently Fords use it often since the like to pop plugs out of the heads... So, I'm set yet one more time.. fucking stupid car!!!
    [/rant]
    -Gio
    My E85 Turbo Build
    5280FEST
  9. #284
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Shit sucks.
    Andrew.
  10. #285
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    That sucks to hear... you should try a Helicoil kit. We use them at work and they seem to work quite well for things of that nature.
  11. #286
    SEi User
    Jan 2004
    Don't use JB weld if you can incase it gets stuck to the plug unless you going to fill it up with that and then re tap the thread again? Helicoil allways seem to work and not fail after so not sure whats up with what ever the head shop used obviously sub standard or they're work is! lol!
    Can allways take it off again and throw it back at em! Might be worth sniffing around for a spare head just in case or if you have a spare then getting prepped and ready so you can do a straight swap! (That's what I do anyway allways have a spare of something ready to direct swap over!)
  12. #287
    LXi User hondalude86's Avatar
    Dec 2003
    1986/Honda/prelude si
    Denver Colorado
    Yeah, these heads seem to be quiet soft for sure. My head on my read car had two buggered spark plug holes, but I got lucky and just ran a thread chaser through it and it works fine. I've learned from my previous preludes/accords to ALWAYS use anti-seeze on spark plugs and to only remove my plugs on a cold motor
  13. #288
    A Mile High.
    Yeah, I didn't use anti seize, and pulled them after driving home from work..
    So you guys recommend Helicoil over Time-Sert??? And no JB weld??? I'll post up a link of what I meant...
    -Gio
    My E85 Turbo Build
    5280FEST
  14. #289
    Nov 2008
    Las Vegas, NV
    I've never used time serts so I can't say anything bad about them but I would recommend helicoil since I've never had a problem with them.
    Build Thread
  15. #290
    Dec 2003
    Denver Colorado
    i've never really used either, but i've never heard or "time-serts" see next time you'll use some Anti-Seeze on those little diddies
  16. #291
    SEi User
    Jan 2004
    Highly recommend copper grease on plugs mines been in and out hundreds of times and I've never had an issue with stripped plugs or plugs stuck. Think this is pretty common procedure on any petrol car is it not?
  17. #292
    A Mile High.
    Yeah, my buddy and a lot of shops around here recommend time-serts.. They're not as known like helicoil is, but they're supposed to be a bit better.. I'll def use more anti seize on everything now!!!
    -Gio
    My E85 Turbo Build
    5280FEST
  18. #293
    cygnus x-1's Avatar
    Chicago area
    If the threads on the insert and head are still ok, and the insert will thread back in all the way, try this. Pit a little red loctite around the upper part of the insert and thread it back into the hole all the way. Let it sit overnight and then try removing the plug again. The loctite should hold the insert in and let the plug come out.
    C|
  19. #294
    A Mile High.
    That's the problem with one of them
    I just messaged the guy that built the head and told him he needs come down and get this shit fixed.. A new kit to fix this is like 200 bucks!! Plus then order the parts needed... fml..
    -Gio
    My E85 Turbo Build
    5280FEST
  20. #295
    A Mile High.
    Head came off. Went back to shop. They fixed it, and are providing all gaskets... hopefully she's back up tonight.
    Also got Odyssey battery and tray. Pics of that tonight
    -Gio
    My E85 Turbo Build
    5280FEST
  21. #296
    cygnus x-1's Avatar
    Chicago area
    Dude, that looks like it melted. Does that sleeve stick down into the combustion chamber? That's really strange.
    C|
  22. #297
    SEi User
    Jan 2004
    Hmm looks well dodgy! how hot is the engine running try running it cooler if you can? Or maybe you need colder plugs especially with the turbo etc. what ones are you using?
  23. #298
    Dec 2003
    Denver Colorado
    Looks like a hot plug that was in a hot motor and got stripped out...
  24. #299
    A Mile High.
    I'm not quite sure why it did that. But my buddy told me he's seen this happen when the serts aren't installed right (loose) they burn up.. The plug was fine. It was the sert that got fucked up. I got the head back Monday night. I just have been really busy, so haven't installed it yet...
    Rich, the turbo hasn't gone on yet.. As soon as the head goes on, the install will begin
    -Gio
    My E85 Turbo Build
    5280FEST
  25. #300
    89T's Avatar
    Apr 2004
    Quote Originally Posted by hondalude86 View Post
    To me, It looks like a cylinder temp issue. Possibly not enough timing causing detonation. What was the afr as the problem came about?
    un-motivated!
    3GR
  1. Piter's 1987 Prelude BA2 build thread
    By piter in forum Classic Preludes
    Last Post: 02-08-2012, 03:13 AM
  2. gfrg88!!!!!!!!!
    By EX-ileAccord in forum Classic Honda Community Chat
    Last Post: 09-15-2006, 06:59 AM
  3. gfrg88 Photoshoot
    By Cheeseburger in forum Classic Honda Pics & Videos
    Last Post: 07-13-2006, 09:54 PM
