Page 9 of 20 FirstFirst ... 567891011121319 ... LastLast
Results 201 to 225 of 498
Thread: A18A's 1988 Vigor 2.0MXL
  1. #201
    Re: A18A's 1988 Vigor 2.0MXL
    sweet h22
    (y)
  3. #203
    it's alive and powers its own wheels, now i have to do all the shitty boring stuff of tidying it up making it work mint
  4. #204
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Sweet!
    Is it touching the firewall?
    Andrew.
  5. #205
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Nice! Another H22 3gee on the road!
    1989 Honda Accord LX-I 300K+
    Build Thread
  6. #206
    Sweet!
    it's very close, i had to cut out the torque rod mount thing and bash some of that lip away from just under the chassis number. I also had to bash the frame rail a bit for the crank pulley to fit properly, and also the subframe that holds the steering rack. I didn't realize how big these motors where till it was in the engine bay
    I took it for a drive today, left side axle binds like fuckery under load. i'll just chop some of the cv joint off till it works. that will do until I can get me a mid shaft from a 4g accord. drivers side axle works mint though, it's a EF civic axle with a 90 accord inner CV
    power wise, I'm currently using a dohc f22b ecu (no vtax) and it's about as fast as a good running b20a. so it should go mint once i've wired up all the extra stuff and install the h22a ecu.
  7. #207
    Nov 2008
    Las Vegas, NV
    You need VVVTTTAAAKKKK!!!!
    Build Thread
  8. #208
    I just spent all night converting this
    into this
    the car is permanently obd1 now. I'll tidy that up tomorrow.
    the h22a has 2 ECTs, I don't know where to wire the 2nd one. I get error codes for ELD (using an Accord alternator instead of a prelude one) and a o2 sensor heater error, dunno why, sensor must be fucked
    i put the gauges with a electric vss in (no more cable yay)
    power steering is also all done now and works the best ever since i've had the car
    almost complete, main things left that need doing are:
    notch the stock crossmember (for the exhaust) and put that back on
    install a heatshield between the exhaust and shifter cables
    modify my passenger side cv joint
    install teh dual core radiator
    and get another rocker cover
    sweet!
  9. #209
    are you excited about having a vtec accord that u made by yourself that wont pass a Warant of Fitness Check???
  10. #210
    still havent driven it yet lol. i'll make my car wofable some how
  11. #211
    at least now the mounts are sorted you can pull out the engine and get someone to weld the mounts and make them look prety
  12. #212
    i really wont look forward to pulling the motor out of this, that will be like a whole day job just to get it out
  13. #213
    i took it for a blat today, car goes hard
  14. #214
    amazing!
  15. #215
    vids!
    vids after the car is fully functional
    today i decided to notch the accord front cross member to clear the exhaust(cause the prelude cross member had too much fail going on) obviously i didn't measure before cutting and cut it way off target
    never mind, it turned out all good
    installed a stock radiator, wrapped the hose joinery things in tape to fit the bigger hoses
    not much room between my the fan and my churr bro clutch adapter
    should have a rocker cover by the end of the week if things go to plan
  17. #217
    lol measure not at all and cut 30 times!!!
  18. #218
    Nov 2008
    Las Vegas, NV
    Is it functional now?
    Build Thread
  19. #219
    i do drive it yes, but it still needs a axle, exhaust heat shield & a rocker cover before i'd call it complete
  20. #220
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Nice swap Matt!! And Im digging the yellow top valve cover lol
  21. #221
    that wont be around for much longer, there should be another one on the way to me right now
    also fixed the axle binding problem, i removed both clips on each end of the axle so i could move the cv joint & bearing holder as far back on the axle as they can go, on the outer end i welded it to the cv joint, on the inner end i just slid the bearing holder thing as far back as it would go. hory as, but is working good for now lol. now i can replace the upper & lower ball joints on that side that have play in them now lol
  22. #222
    told ya that idea would work
  23. #223
    indeed. hope it's reliable lol. now my rocker cover should just hurry the fuck up and arrive!
  24. #224
    i reckon. then u need to get some fuel and come a visit au
  25. #225
    lol yeah, when i have money to throw around. i washed the car
  1. A18A's 1988 Accord 2.0Si
    Last Post: 12-13-2013, 03:32 PM
  2. Installing a Vigor garnish on a non-Vigor trunk lid (with PICS!)
    By Hazwan in forum Interior & Exterior Care
    Last Post: 07-03-2012, 07:57 PM
  3. vigor
    By tsumi88 in forum Classic Honda Community Chat
    Last Post: 07-26-2010, 01:20 AM
  4. Help this guy with a 86-89 Vigor.
    By diegoaccord in forum Classic Honda Community Chat
    Last Post: 02-15-2010, 08:43 AM
  5. vigor and accord???
    By A18A in forum Classic Honda Community Chat
    Last Post: 11-20-2005, 11:44 AM
