Results 1 to 25 of 25
Thread: Hard fuel line question "b Series"
    K well i just install my b16 manifold and it had the old style rail and i had a leak problem. For those of you that put a b16 manifold on did you switch the banjo bolt line from the filter to the rail.
    I mean it fits but the rail dont have a hole threw it like the stock one did. SO here are a couple pics
    Here is my stock rail. See how there is a hole in the bolt.
    This is the B16a Rail. I had this one on and i had a fuel like using the cap that went with it. I didnt notice that it didnt have a Hole threw it either SO im like UMM thats why i have a leak!
    i was also woundering why is there a adjustment screw on the surge vavle? the more i screw in the place in the nut "if you looking in it" goes back further. So im like confused LOL
    Maybe i need this washer?
    SO i didnt like how it looked. So i forgot that i had a newer style Obd1 b16 fuel line. has the same problem. It fits but there is no hole! Do i still put it on and run that cap. How would the fuel enter?
    This would be usefull for people doing the same. I havent gottan the d series fuel line yet since they fit.
    Help me out.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: Hard fuel line question "b Series"
    Im guessing you using the stock Fuel line for the A20 fuel rail? Have you thought about getting the B16 fuel line for the B16 fuel rail? it could have different ends or something?
    im sure i can find a eg at the yard or a EF since they have the same style. I was just wounding if i could use my line.
    Bump! No one else huh . Weak sauce
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I don't know man, I'm in the same boat. Maybe drill a hole in the fitting like the stock a20 one?
    Andrew.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    iirc, that's what I did on my accord.. don't remember too well.. I just have the b16 fuel line, and I'm gonna try using that.. Haven't gotten here yet, and it's been soo long since I did it..
    -Gio
    My E85 Turbo Build
    5280FEST
    Let me know. I can drill a hole but it would be a bitch lol
    A Mile High.
    I'm gonna check for you tonight after work, and I'll let you know..
    -Gio
    My E85 Turbo Build
    5280FEST
    cygnus x-1's Avatar
    Chicago area
    Does the fuel go through the pressure damper somehow? Can you take a picture of the threaded side of the damper?
    C|
    surge valve cap you mean? yeah i can take a pic of the inside. But seems i need a b series fuel line or make one.
    cygnus x-1's Avatar
    Chicago area
    You know, I just remembered, there are two types of Honda fuel fittings, one with the surge thing and one without. They are not interchangeable so if the A20 line doesn't use a surge damper it won't work on the B type rails. You need the B type line.
    C|
    89T's Avatar
    Apr 2004
    un-motivated!
    3GR
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I have those, so I'm not sure how that helps the question.
    Since b16 don't exist around here and I don't really want to buy new... Should I just spend the extra and go with AN and some stainless line?
    Andrew.
    cygnus x-1's Avatar
    Chicago area
    Could you not just use a B18xx fuel line? I think they all use the surge damper.
    The banjo/AN adapter plus AN line would also work. That's what I did when I was running a B18A1 intake and rail.
    C|
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I will have to look at some b18's next time, as those are much more common here.
    The AN stuff is awesome ...but holy shit is it expensive.
    Andrew.
    89T's Avatar
    Apr 2004
    Josh has some pics i took for him. hit him up.
    un-motivated!
    3GR
    K thanks Jerry for your help. But I didn't have the money for AN fittings so did something easy an effected Rendon syle lol
    DIY convert your stock line to a b series syle to fit on a pulse damper style fuel rail.
    Tools needed:
    Dremel
    Step bit
    Break clean
    Compressed air
    1. Take your stock line off after you disconnect your battery.
    2. Compare bolt lines short one 91 ls teg "used as a guide for the hole on the banjo end" an long on is the stock accord one
    As you can see that the back face "that goes against the rail" has a small hole
    3.this is the other side where you bolt / surge valve tightens as you can see the ls "top" is way bigger for fuel flow
    4. You need these tools to do this task properly
    Why I recommend the step is cause I can measure how big the ls hole is an then step drill to what the ls line end was.
    5. After drilling the stock line "bottom" you can see it's the same as the ls line. Take your time the slow you push the cleaner the cut an stop after each step on the bit. Remember how many steps to go down . Or else your fawked lol.
    6. Finished product stock accord line to newer syle pulser damper fuel end type. This is where I used the dremel to smooth out the edges an in inside an make everything clean" take your time an once done spray an clea. With brake clean. Shoot also down the slime from the other side then hit it with te blow gun. Bam done
    O you need this after this mod is done
    Special pulser nut an this washer is needed also " I got mine off a DA"
    Now I got a cleaner setup . But a few minor problems I have a really low oil pressure 10 psi at idle so I'm prolly going to replace the oil pump here shorty. Other then that pretty straight forward
    Bump
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Ohhh, thank you very much man. I will do this until the one day I can afford some AN stuff.
    Good job!
    Andrew.
    Thats why I posted the how to. Hope I helped you out man. Now 3G guys can do this whit out much money. Easy how to if you understand it. My bad on some words
    cygnus x-1's Avatar
    Chicago area
    Custom fab work! W00t!!
    C|
    I say good sticky . Cheers
    I think the 86-87 have a different line than a 88-89 because mine just bolted up with no problem
    same here ive never had an issue. mind you all of my fuel lines arent factory ones they are of other cars like b16s and b18b's
  1. Replies: 1
    Last Post: 04-18-2009, 01:41 AM
  2. Which "a" Series Engine Is This?
    By evil88accordLX in forum Classic Honda Community Chat
    Last Post: 04-19-2008, 11:20 AM
  3. carb fuel pump "survey"
    By njpeter in forum Carburetor Tech
    Last Post: 02-06-2003, 09:01 AM
  4. The damn fuel filter "Special Banjo bolt"
    By Chrome_thangs in forum Performance
    Last Post: 07-15-2002, 11:57 PM
