Dude, you should have hooked up a rear sway bar! Just fyi, you should be running your fronts nearly full soft, just enough to keep it from bouncing, and then running your rears at nearly full hard! add a sway for the low speed courses and remove the sway for anything your going to see more than 70mph on! I'm not going to lie, my current suspension driving at the limit at more than 70mph is a little bit sketch! Once everything is set right, you should be able to adjust how much oversteer you want with the amount of compression in the rear shocks... you want more, turn them up, you want less soften them up. Just looking at your pics (mostly the last one) is telling me that you may have had your *front shocks a little high on the valving, just suspecting anyway
