I did a quick search and found nothing about somebody trying a carb to TBI conversion. Need to say the following first:
1) I'm really happy with my carb performance. But I'm getting bored.
2) Not interested in the $600 USD aftermarket TBI.
3) Not interested in a FI donor car.
4) I know the advantages of a multi port FI over the single port FI. But I also know the advantages of the single port FI over the carb.
5) I will build my own ECU. I'm most worried about the mechanical portion of the system than the electronics.
6) I'm thinking this may be my next project.
I owned a chevy monza some time ago with the Single Port or TBI system (sold only in Mexico, I think), honestly, I never though about the fuel system it has, because it never gave any problem.
I have on hand an in-tank Fuel Module with a pump, filter and regulator, everything integrated in a bucket that fits my fuel tank. So check mark to this part of the project.
Then I'll need to:
a) Adapt a TPS and a Mass AirFlow Sensor to the Carburetor, and start collecting data while its still carbed. So when I start writting my code I know the range of the input values at all drive conditions.
b) Get a Chevy Throttle Body Asm from a JY, make and adapter plate and throw it into the OEM intake manifold.
The plan is to start writing the "default" program which every single ECU runs when any input goes bad, which estimates the missing signals just to keep the car running.
If that part of the project works, then I can think in compensate for temperature, altitude etc.
