Results 1 to 18 of 18
Thread: Time to Call the Tow Truck
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Rear upper control arm replacement
    Tonight the rear right ball joint on the upper arm gave out, ill have to see if there is anything else messed up, any suggestions as to fixing it myself
    Your Honda, isn't my Honda.
    Re: Time to Call the Tow Truck
    put in a new one?
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Yeah im checking as to going about doing that
    yeah easy with new arms and ball joints
    Washington
    hopefully when it gave out the hub just slide inward and rested on the spring. If so you probably dont have any other damages. i would look for clean spots, those would have been rubbed. I would also look at those spots for stressing of the paint. Chances are if this one went the other is right behind it.
    Quote Originally Posted by SkateK610 View Post
    If you buy the stock one its a bolt in deal to the car you just need to separate the ball joint but since yours did it itself already your ready to rock and roll
    I would change both sides there a short wear item on our car.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Its really easy to be honest with you. Should only take 15 minutes or so with it already being separated. I will x3 the suggestion to do both at once, as your other one is right behind it.
    '89 SE-i Coupe
    Awaiting Garage
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    I ordered a new arm so hopfully tonight after work i can fix it out, the nut with the cotterpin is pretty much rusted/corroded to hell, hopfully i can get it off somewhat alright, but thats usually never the case
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    After lots of trying to free the nut we decided the last option was some hose clamps, and i cant believe the 3 of em held for the 5 mph 3 mile journey home.
    that nut is rusted up pretty good and the cotter pin is broken and still in there, any suggestions?
    put in a new one?
    first you should remove the old one
    try soaking it overnight with some pb blaster or wd40..you may have to beat on it with a good heavy mallet to loosen it up.
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Nice ghetto get you home repair!
    Remove all traces of the cotter pin if you can. Take off your savior hose clamps. It looks like the joint will self-separate, ball from socket. Use liberal amounts of your favorite penetrating oil on the nut. Grab the ball (or what remains of it) with big Vice Grips and wrench the nut off.
    Another option is to cut just the nut off leaving the threaded portion intact.
    Hoprfully threads aren't too fucked for the next step.
    Put another nut of same size and thread pitch a couple of turns on the threaded portion of the ball joint. Force the tapered end of the ball joint out of the knuckle with a Pitman arm remover or similar tool.
    Learn from the mistakes of others. You'll not live long enough to make them all yourself.
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    The screw had no threads on the end it was so corroded, the nut was too far in to get a grip with anything.
    We cut the top of the ball off but the screw was rusted shut in there hammering it wouldnt budge so i drilled though the length of it hoping to collapse it but still nothing, then my dad took a chisel to the nut and hammered it off, after that it took some heavy hits to free it from the knuckle.
    But alas 3 hours later its replaced.
    car6289's Avatar
    Jun 2002
    Good on ya! Ingenuity wins the day. Don't forget to change the left side sooner than later.
    well now you know to coat the new parts with some grease so they dont rust again
    That's some good work there.
    Deff change the left side man!
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    I remember the last owner saying some stuff was changed on the suspension, the left side looks newer and wasn't original but for $20 shipped on ebay i cant afford not to
  1. So is it time to call it quits?
    By Reptile in forum Classic Honda Community Chat
    Last Post: 04-17-2008, 07:45 PM
  2. 3g TRUCK
    By fraza in forum Classic Honda Community Chat
    Last Post: 07-09-2006, 12:23 PM
  3. One tuff truck.....
    By Bglad420 in forum Classic Honda Community Chat
    Last Post: 02-07-2006, 12:28 AM
  4. 87 accord truck
    By johndej in forum Classic Honda Community Chat
    Last Post: 01-22-2005, 10:36 PM
  5. Truck Intake!?
    By sccrsteve5 in forum Performance
    Last Post: 01-12-2004, 05:26 PM
