Results 1 to 5 of 5
Thread: over cooling/not heating enough
    May 2011
    87 HONDA ACCORD LX CARB 5SP MAN. 283K
    CALIFORNIA
    Question over cooling/not heating enough
    ok so i will let my 87 warm up and the farthest it will go is a couple of degrees lower than half. before it would warm up too half way and it would remain there unless it was cold and i was on the freeway. so my question is could it be a faulty fail safe thermostat or can it be i got bubbles in my cooling system or is that normal? any input will be helpful thanks
    Re: over cooling/not heating enough
    Definitely thinking it's the thermostat.
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Mine was like that, bleed the cooling system, make sure ALL the air is out
    Your Honda, isn't my Honda.
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    Its normal for the temperature gauge to be at half way or a few millimeters below half when completely warmed up. I think if your thermostat failed it would be at a quarter or something. You can always check the thermostat, make sure there is enough coolant and good coolant in there, then bleed the air out.
    Edit: also make sure that your thermostat has the small hole in it to help bleed the system. The hole should be positioned so its at the top when installed.
    1988 Honda Accord LSDX-I
    May 2011
    CALIFORNIA
    Thank you very much for the input ill check that right away thanks
  1. Heating
    By accordfan in forum Classic Honda Community Chat
    Last Post: 12-26-2012, 07:25 PM
  2. heating up
    By gengen35 in forum Performance
    Last Post: 07-28-2006, 02:42 PM
  3. no cooling or heating
    By 88' ACCORD LX-i in forum 3geez Accords
    Last Post: 12-01-2005, 05:09 PM
  4. over heating
    By bugzboy85 in forum 3geez Accords
    Last Post: 03-11-2004, 03:15 PM
  5. Heating Up
    By dub88acc in forum 3geez Accords
    Last Post: 01-18-2004, 06:13 PM
