What are our option for HIDs, I seen conversion kits on eBay but do I need to replace the entire headlight housing? If not what size HIDs do I get for my 88 lxi?
Search!
I did but too much comes up when I search "hid/h.I.d", or ,headlights". I could end up realding old post for weeks lol
I read somewhere that all hondas use the same bulb... Idk if that is true but if someone knows the answer to my question that would be awsome, thanks.
our cars came with a sealed glass bulb. you will first have to get a H4 housing that is a the glass part but on the back of it you can switch out the light bulb. The HID kit will have to be a H4 so then you can just install the HID light. most of us use Hella or autopal housings that can be found on ebay.
That is completely and utterly untrue due to the fact that some Hondas use sealed-beam, single-filament bulbs, some use sealed-beam, dual-filament bulbs, some use open-beam, single-filament bulbs, and some use open-beam, dual-filament bulbs. Some newer Hondas might even use light emitting diodes, but I'm not sure Honda has reached that point, yet.
Really you should do a retrofit...
*Car Un-related, but headlights are the same.*
What dustin said. HID's in a proper projector vs HID's in a Hella/Autopal housing are worlds apart. And I'm not talking about those ebay "projector" lamps, I mean a proper FX-R/TL/even mini H1 or mini D2S projector. Hit up the hidplanet forum to learn what you need to.
