Results 1 to 11 of 11
Thread: 02 sensor
    Sep 2010
    1989 Accord DX 2dr
    02 sensor
    How do you guys get the 02 sensor out on an 89 accord dx carbed coupe? There is hardly any room to maneuver and mine seems to be rusted in solid because it won't seem to budge... Any tips or tricks?
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: 02 sensor
    Quote Originally Posted by pink_sleeve View Post
    gotta keep on trying eventually it will come off.
    LX User elpuma's Avatar
    May 2009
    88 Honda Accord lxi
    Grants Pass/Corvallis
    Re: 02 sensor
    You can try removing the radiator out and see if that will give you some more room.
    I/H/E, B16 mani, delta 272, OBD1....etc
    Re: 02 sensor
    you have to use pb blaster or liquid wrench. they have a special O2 sensor remover and then it comes out. might take a few tries
    Re: 02 sensor
    what i do is smash the fuck out of the sensor and stick a socket and a big bar on it
    Oct 2009
    Re: 02 sensor
    i used a 7/8 wrench and started turning and in seconds it was off.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: 02 sensor
    big wrench pb blaster and a hammer or leverage device and you should be golden
    Re: 02 sensor
    Quote Originally Posted by elpuma View Post
    Or the cooling fans at the very least.
    Sep 2010
    1989 Accord DX 2dr
    Re: 02 sensor
    Thanks for all the help and suggestions guys. You guys truly are helpful. I was able to remove my heat shield and that totally exposes the sensor. So I soaked her with pb blaster and she came out no problem. No big hammers required this time lol. I got this replaced and the cap, rotor, and some new plugs and she passed echeck with flying colors... I noticed when I had the cap off there was oil inside my distributor and I'm guessing this isn't normal? Is this a sign that the dizzy oring needs replaced? If so I'd assume you also have to replace the valve cover gasket at the same time correct? I was planning on attempting the timing belt as well this summer and the water pump also. Anybody have a list of what all to replace while the timing belt is being done?
    Re: 02 sensor
    It means your distributor is toast.
    Sep 2010
    1989 Accord DX 2dr
    Re: 02 sensor
    How does the car still run then? It might not have been oil but you could def tell it has been wet inside before?
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    Last Post: 11-03-2002, 07:23 PM
