Page 24 of 25 FirstFirst ... 14202122232425 LastLast
Results 576 to 600 of 616
Thread: Rendons Offical A To B series thread!!!!
  1. #576
    Re: Rendons Offical A To B series thread!!!!
    Can't wait to see the beast in Portland! And get a ride?
    so good to see this actually going now (Y)
    Of course John. An tell me about it Aaron lol
    I always love ur car.... When it runsJk
  3. #578
    Lmfao
    time to update my thread. lol well its come to end as for the SWAP plenty more to do but ill be doing a how to very detailed which was a idea john gave me. help some future youngsters swap out there 3gen. lol
    so now whats left to do is
    type r calipers and legend/mini cooper rotors
    rear break upgrade rotors/calipers
    repaint car
    install prelude rear seat to match lude interior
    k sports will be needed.
    ill will be doing the odyssey pc680mjt MJT is metal jacket so i wont need that special holder ill use the jackit as a holder cheaper,cleaner. getting rid of the rear batter. going for the clean look oem style. no more rice bs lol.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    repaint car
    What's your compression? the PC680MJT is a 220CCA battery, which, yes brand new will do the job. But you hear all these guys talking about "Make sure you keep it charged or it wont start your car." is a bunch of BS. Its a gel battery, it will stay charged fine on its own. The reason it won't start your car is because it is VASTLY under-rated for most of us.
    '89 SE-i Coupe
    Awaiting Garage
  6. #581
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Dont forget you rear bumper
  7. #582
    hammer3rd's Avatar
    Sep 2008
    2000 Powerstroke 1988 LXI sedan
    Claremont
    Yea dizzy was giving to me cause of check engine light . Tdc code never came up. Till a couple days after. I installed shielded wire which why I was getting code 8,9. Was getting code 17 as well I stacked 4 1.5k together lol to get 6k. Hopefully that fixes that problem. Car still does not fire after it died checked for spark no spark. My wiring is correct or the car would of not ran. Codes popped up after going the first full wot but I did check an everything was up to my standards .
    Did you parallel or sereies the resistors. Series you will get 6k +/- from 4 1.5k resistors. But parellel you will only get .375 or there about depending on the +/- range but close the that number. Which are you looking for?
    Mike C in NC USA
  8. #583
    hammer3rd's Avatar
    Sep 2008
    Claremont
    Actually a strut is the alternet when it comes to coilover suspensions as it plays double duty in mounting the upper part of the suspension also. A true coilover is only a shock and spring and was introduced long before the strut. Oh sorry to but in Rendon but damn nice job on the car. Cant wait to see it in action.
    Mike C in NC USA
  9. #584
    Specs say its 550cca? Lol either way its a bad ass battery. Should be plenty
    Quote Originally Posted by ShyBoyCA6 View Post
    Already got that lol
    Quote Originally Posted by hammer3rd View Post
    I just put em in series which worked but I just. Swapped clusters an called it a day no more cel.
    Car is already in action bro . I posted links
    Compression is 11:5.1
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Josh, car is looking great! Glad to see it's up and running and you can enjoy it now... The PC680 is rated at 170cca from Odyssey... http://www.odysseybattery.com/battspecs.html
    So, I'm not sure if you'd have any issues with it. I have been running a PC925 for a few years now and it has been really good and I have a pretty decent stereo too.
  12. #587
    Is the 925 same size?
    Calgary, AB, Canada
    No Josh, the 925 is a bit shorter in height, but probably double the width.
  14. #589
    Updated 1st page on a how to.
    Little update. As you know I'm using my stock pump which is not enought for high revs I got a habit getting in it an just dont want to risk damaging nothing so I put her up for the winter early.
    Going to install a fuel pump relay kit an getting a fuel pump 255lph both from xenocron . Putting the fuel pump relay would give me full 14 volts which not only would I get true voltage to the pump but also prolong the life of the pump by supplying it with the voltage it was suppose have. Ill do a how to on that so for those that want to have the info an pics needed.
    I tested the power output which I was getting 11.35v (when I had a no start) cranking an cranking an finally figured it out. it was my pump . So I think that reading was from the battery Beening low plus it's in the back .
    I'm also putting the battery back up front just don't like the setup I have.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Dyno yet?
    -Gio
    My E85 Turbo Build
    5280FEST
  17. #592
    Nope. Can't afford that right now
    A Mile High.
    It's not that much.. I'll paypal you the amount. I want to see that 200+whp on paper....
    -Gio
    My E85 Turbo Build
    5280FEST
  19. #594
    Lol it is 200 hp . Feels like it an tuner said its 200 by his Experiance . Ill get it dynod. Most Ls Vtec setups like mine are 220-227. Running 13.5
    A Mile High.
    Not doubting it. I meant the dyno isn't that much... I'm just a sucker for shit like that. I want more vids, pics, dyno, and shit.
    You sticking n/a, or boosting later on?
    -Gio
    My E85 Turbo Build
    5280FEST
  21. #596
    N/a for now. It's feels boosted lol. Hopefully next meet I can do it in Seattle. There is no dynos here. One we had got shut down
    Seems like a have a ground issue. When I have lights on heater going an stereo going its fine till I stop then it idle fine then drop then pick up then drop stumble then pick up. This was going in with my a20 as well I taught it was just the motor. Need to do a voltage drop an see what's going on. I have good grounds. Harness ground is on the intake runnier . That's the know ground I think that is shitty.
    Performed a voltage drop. I had a good ground. the engine bay harness ground wasnt great. was getting .2 which wasnt up to my standards lol. moved that ground to the alt bracket an put valve cover ground to the strut tower. best ground ever.
    fixed my rear sensors and no more lamp out light in dash.
    Replaced fuel sender unit with a used one and same issue with the bouncy fuel needle. Ill just leave it lol.
    LX User elpuma's Avatar
    May 2009
    88 Honda Accord lxi
    Grants Pass/Corvallis
    Can a moderator sticky this in the general engine swaps? I believe this is a good thread that qualifies. Josh has updated his first page to include everything he used to make the swap possible. It is also a very current swap.
    I/H/E, B16 mani, delta 272, OBD1....etc
  25. #600
    89T's Avatar
    Apr 2004
    +1
  1. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  2. *!*OFFICAL*!* MUGEN thread
    Last Post: 02-11-2010, 07:39 AM
  3. $%# offical non-pop up head light thread#%$
    By ZackieDarko in forum Classic Honda Pics & Videos
    Last Post: 07-08-2009, 01:49 PM
  4. My B-Series Swap Thread
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 02-12-2009, 06:29 PM
  5. Reupholstery Offical How-To Thread
    By gr3k0sLaV in forum Interior & Exterior Care
    Last Post: 08-10-2007, 03:54 PM
VigLink badge
