Page 4 of 25 FirstFirst 1234567814 ... LastLast
Results 76 to 100 of 616
Thread: Rendons Offical A To B series thread!!!!
  1. #76
    Re: Rendons Offical A To B series thread!!!!
    Thanks man. That's what I'm saying might as well be one piece lol. I could of bashed it in a bit with a BFH. But it's fine.
    Man that mount is close. I was thinking it might hit, but I guess it's bolted to the subframe, so it won't move, but the engine will move on it... So, are you the first person who has actually installed these mounts?
  3. #78
    Idk. I haven't seen no pics but legends an his pic looks just the same. I might bang it a bit with a BFH . Just to give it some clearance
    losen the subframe bolts you may be able to pull the subframe forward to add more clearance.
  5. #80
    I'll try that .
    Little update. Did some wiring clean some wires up. Extended some an added the obd1 dizzy plugs to the existing harness. So harness is done. Need to add he extension harness an add the cyp wires an icm wire.
    i thought you would have ditched the accord efi loom and run a civic one as a standalone lol
  8. #83
    Nay. Why fuck with all that . Its simple this way an I Deloomed an took out what is not needed a. Kept what I wanted. I bascily did what legend did
    89T's Avatar
    Apr 2004
    are you done yet? Lmao.. I need ripper vids1!
    un-motivated!
    3GR
  10. #85
    Not yet. My b18b1 is in Portland. Once I get that I can tear it down an get th bearing specs swap out pistons.
    Washington
    is the trans mount a direct bolt on or do you need to drill holes in the fender walls to bolt it on? Got pics of it mounted?
  12. #87
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    kwik your pic scares me
  13. #88
    No it has to be welded. I have pics in the beginning of the thread
    Washington
    without the motor installed how would you tell where it has to go? Wouldnt the axles need to be placed and the car on level ground with the motor supported level to mark the location?
  15. #90
    No. It's pretty straight forward u can see where u can install the bolts,one fits. But I don't trust 10mm bolts lol. Basically u can't put it on wrong unless your a fruit.
    i think innovative should of made their own mounts because the place racing mounts were not the best fit.
    hasport mounts dont have fail
    Its good to read a thread about a b series swap thats actually making progress
  18. #93
    Thanks Arron . U know me I get er done.
    I agree with messy. But at the same time they took the mounts an the time to redo em. So atleast we have mounts.
    Badass man, good to see another b-swap. Hopefully I can actually get mine running soon. That brake line thing is kinda of a pain in the ass. Looks like those mounts are a little different then the PRI. My rear mount is not that close to the firewall, and my transmission mount bracket lines up with the holes in the side rail perfectly. They still look very similar.
  21. #96
    I need to get my tranny I found a y1 for 250 so I'll see if I can get it in a week.
    The mount almost lines up but shouldn't be off. Well have to see. Hopefully it be dropped in in a couple months.
    Question do I used b16 head studs or gsr. People can't mak up there
    Mind on Honda tech lol
    I used Gsr head studs when I did my ls/v with a Gsr head. They are actually all the same, but personal preference wise I would go with the b16 to match the head.
  23. #98
    That's what I was thinking. Thanks man. What lsv kit u use?
    I used the golden eagle oil sandwich, and a generic turbo line for the oil feed. I also had the head modified to fit a factory head gasket from an LS.
  25. #100
    Oright. They have the special dowels now so I should be ok from he reviews I saw.
  1. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  2. *!*OFFICAL*!* MUGEN thread
    Last Post: 02-11-2010, 07:39 AM
  3. $%# offical non-pop up head light thread#%$
    By ZackieDarko in forum Classic Honda Pics & Videos
    Last Post: 07-08-2009, 01:49 PM
  4. My B-Series Swap Thread
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 02-12-2009, 06:29 PM
  5. Reupholstery Offical How-To Thread
    By gr3k0sLaV in forum Interior & Exterior Care
    Last Post: 08-10-2007, 03:54 PM
VigLink badge
