Results 1 to 7 of 7
Thread: need help from jim!
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    need help from jim!
    ok jim... the low boyz have been returned. they are total shit. nothin works and they gave shit springs. i sold my ground controls and struts and now i am goin to buy a fresh set. what kind of shox are recomended? i had konis all around and now i wanna get tokico's. i think!?! so what is the recomended setup? i dont want bilstiens. and i need to get somthin cuz im back on my factory shox... they are soooo bad. i guess in used to konis and gc's. so what shall i buy?
    Travis
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: need help from jim!
    Travis
    Sorry they didn't work out.
    Why are you looking at the tokico's? Going from Koni's to tokico's is a step backwards that you'll will regret. You had a great set up, get it again. www.shox.com is the best place I can think of to get that setup at. $339 for the GC's and $424 for the Koni's with free shipping. If ya have to I guess you could run tokicos in the rear, but if you can afford the koni's in the rear I'd do that.
    Or kick it up another notch and get stiffer ground controls and have Koni revalve a set of struts (and shorten the front bodies if you plan on running below a 2.5").
    Now I d
    NORTH BAY ONTARIO
    do the bodies have to be shortened if i run at 3 inches? they worked b4 but was there sumthin i missed?
    so i guess ill go for konis again
    Travis
    Central California
    Travis
    Well they will work, but 3" lower means your gonna risk bottoming out a awfull lot unless your super human carefull.
    Ya know if you were willing to slice off the brake line mounts on the front strut bodies you'd be able to let the struts go down into the pinch fork 1 extra inch,.....just like you had the strut bodies shortened a inch. Where the strut body naturally gets fatter will be the new stop for the pinch fork. What you will do with the brake line mounts is up to you. I'd think their would still be enough space below the spring mount's to reweld them on. Just a idea.
    Now I d
    88 Lxi/ 5spd
    Tennessee
    every time i Hear somebody call jim i can hear that forgein girl's accent on american pie and i get all tingly inside......oops i'm thinking out loud!!!
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    :lol
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    Central California
    I don't want to know:lol
    Well now Shannon elizibeth, that I do know, yum yum!
    Now I d
