Results 1 to 25 of 25
Thread: 86 lxi problems starting..
    DX User slowA20tog22's Avatar
    Mar 2011
    1986/accord/lx-i
    vancouver, washington
    so my accord is having problems staying running after it starts right now it idles at 1500 at start up and the backs down to 1100 but when it backs down so times it will creep to far down and die. i was wondering if it is associated with the fuel filter or if its fuel related.. maybe my fuel rail or injectors..
    Re: 86 lxi problems starting..
    I would start with some injector cleaner. When was your last tune up?
    Mar 2011
    1986/accord/lx-i
    well I put in new injectors when Bought the car because the old ones were crappy and had gunky build up on them i also bought new cap and rotors along with plugs and wires. still need to do fuel filter and oil filter i need a new tranny also.. my fifth doesnt work idk where to find a rebuild kit for the tranny
    Are you getting a CEL?
    Mar 2011
    1986/accord/lx-i
    i dont want to sound stupid but whats the "cel"?
    Mar 2011
    1986/accord/lx-i
    no i am not getting a check engine light... idk whats wrong with it.
    Start with a can of injector cleaner and see what happens. If you had gunk on the injectors, you had it all over and it won't run right until that's all gone. Have you checked for vacuum leaks?
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    um when you change the injectors you need to change the fuel filter and fuel strainer. just put some injector cleaner in and see what happens. if it happens again im guessing the fuel pump might be giving out on you?
    Mar 2011
    1986/accord/lx-i
    okay ill try some injector cleaner and a new fuel filter.
    Mar 2011
    1986/accord/lx-i
    so has anyone bought the wrong battery for their car because every time i hook up my friends mustang battery to my car it starts right away but with my other battery it wont...
    Say what? Are you in the habit of swapping batteries with friends often? Just for kicks or what?
    Quote Originally Posted by slowA20tog22 View Post
    In reality any 12 volt battery will work. There is not really a "wrong" one. You want one that fits the space in your car. Even a lawnmower,motorcycle,boat battery would start it in a pinch.
    I think your battery is just bad it does not have the power to start your car. Also make sure you terminals are tight on the battery post. You should not be able to turn them off with your hand.
    Mar 2011
    1986/accord/lx-i
    no only when my battery dies from trying to start my car...
    Sounds like you have a bigger problem. Why don't you provide some more detail? Why is the battery dying? Are you cranking and cranking and eventually killing the battery? Is it not charging fully when you drive? Is the car dying constantly? Your initial description sounds like a dirty fuel system but this sounds more involved.
    Mar 2011
    1986/accord/lx-i
    well the battery gets a full charge the issuse is my fuel pump sometimes doesnt want to turn on. it never dies once i start it and only after i let it sit will it refuse to start i just ran octane booster in it to help out the fuel system a bit. im goin to buy injector cleaner on friday and drive around all day until its cleaned out i already put a new fuel filter on it and that helped out greatly im thinking ut may be the main relay or that i just need a new alternator.. im not sure my alernator the last time i checked was fine but im sure ill need to get a new one... im slowly working on making this car nice..
    May 2010
    1987 Honda Accord LXi
    Alabama
    Main relay is a bear to get at, but a much cheaper part. In my case, extreme CABIN temps would trigger failure. I.e. park car in the sun w/windows closed a while - then it won't start. While I putter around trying to get it started I roll down a window or two and open doors. Cabin temp drops enough and suddenly it starts & works fine. I my case it was the temp inside the car (where the relay is) and not engine temp that mattered! I think main relay failure can cause either no power to fuel pump or no power (or is it no ground?) for the injectors - or both.
    Mar 2011
    1986/accord/lx-i
    hmm well that would make sense my car sat in the sun and right now it started just fine this morning im hoping it will be just fine this afternoon when it heats up to 90.. but if I replaced the main relay would it fix this problem?? i know my fuel pump is good and my injectors are good also.. so i know its a fuel problem because im getting spark and im getting air so im stumped on this issue...
    LXi User Catalyst's Avatar
    Dec 2006
    87 Accord Lxi Hatchback
    Murphys, CA
    I had a similar problem recently, well two problems. Anyways, I would start with repairing / or replacing the main relay. It's really not that hard to get out unless you have huge hands. If that doesn't do it, I would replace the TW sensor, it can also cause your problem. A new main relay is about $40, and a TW sensor is about $20. *$8, and $4 from pick n pull if there is one near by*
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Quote Originally Posted by Catalyst View Post
    Sry for my noobish question but what does tw in tw sensor stand for?
    Dec 2006
    Murphys, CA
    Not sure what it stands for, but It is also called the ECT sensor I think. Engine Coolant temperature sensor. It tells the ECU what the coolant temp is, and the ECU tells the PGMFI system to run differently. If it malfunctions, all kinds of havoc can arise.
    May 2010
    1986 accord LXI
    Chicago Il
    Ok thanks for the response which sensor is it? The one with the green connector or the other one?
    bridgewater.NS Canada
    How come some have two sensors on thermostat housing but mine only has one.
    Because yours is carbureted.
    Mar 2011
    1986/accord/lx-i
    bought the main relay today car starts like a champion
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    TW stands for Thermal Water or Temperature Water sensor.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
  1. starting problems
    By daniel70ca in forum 3geez Accords
    Last Post: 11-21-2008, 10:18 PM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. Starting problems
    By Underdog in forum 3geez Accords
    Last Post: 08-22-2004, 11:44 AM
  4. Starting Problems
    By uneek in forum 3geez Accords
    Last Post: 02-19-2003, 04:47 PM
  5. car has problems starting
    By socal3rdgen in forum 3geez Accords
    Last Post: 12-28-2002, 08:54 PM
