Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 78
Thread: A20 Engine Build Research for Rhonda And Shelly
  1. #51
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: A20 Engine Build Research for Rhonda And Shelly
    Quote Originally Posted by rjudgey View Post
    JIS can get you set of nice oversize pistons in the 9.4:1 CR ratio they are amazingly cheap too with rings and pins. They look to be the same as Honda ones most likely from same foundry in Japan.
    Block seems to be in good condition although haven't seen the pics of the coolant passages this sounds like there maybe an issue there.
    As for headwork be very suspicous of anyone offering headwork that cheap chances are 99% they'll be crap and more likely to do more harm than good!!
    Make sure you stick this thing back together with Felpro gaskets and use a new water and oil pump.
    ill get more pics on the top side. But when I left to NV the wind blew off the plastic bag and some light rust started to come around. I wonder if hot tanking would clean it up.
    I hear ya on the head part I found this other place that does rebuilds so im gonna check that out. Ill see if I can get the specs you listed in the first page.
    If any of the main bearings are spun the crank and the block are junk. You also can't run b18 pistons unless you change to an b18a/b rod and I think b18 pistons have a different wrist pin height so idk if they will work in an a20.
    No spun bearing were found but ill take more pics. Hmm I see.. I guess ill have to find another block and assemble another. The current engine I was using spun bearing number 1 and slightly nember 2 &4 so number one would knock alot. <-- tthis one I wont be using and will be scrap.
  2. #52
    Oct 2009
    On to the pictures: Note: not a pretty sight. Sorry for shitty photos all taken by Phone.
    Crank Bearings And Caps:
  3. #53
    Oct 2009
    Now on to the Pistons and rods:
    [IMG]http://i981.photobucket.com/albums/ae295/Prettyboi_22_/2012-05-03_19-23-30_729.jpg[/IMG
  4. #54
    Oct 2009
    Stupid laptop froze on me and got fed up that i broke that POS in pieces. Thats the last time i buy a DELL! well im using my uncles laptop which he nevers uses ill probably buy this one off him. well more pics sorry for my rant. now back to the thread.
  5. #55
    Oct 2009
    Now this might look bad but in person it doesn't, the stupid bag flew off and a lil bit of water got in and this happens. it didnt look like this at all when it was in the car when i was inspecting it. well i think thats it for now i have more pictures but i think thats enough for today. ill be going to Honda dealer ship to order their gaskets and hopefully still make the head gaskets as i seen they are discontinued.
    Next up is the Head so i can get the Cam off and send it to bisimoto for a regrind :Cheers: if this motor does not satisfy me ill be taking it apart again to build it for the power. Hopefully the torque will be close to 135 or so now that would be a good DD i might out a Stage 2 clutch if i go any higher in number.
  6. #56
    Oct 2009
    Coming soon Medium forced induction for a mild build. still leaving room for more power if i decide to want more hp.
  7. #57
    yup that was going to be my build too. Mid build and break it in NA and then turbo later once the engine is fully broken in and have more time to have a good turbo set up. im sure a mid built a20 could handle at least 15 pounds
    Oct 2009
    Um for the crank bearings i can't seem to find the ACL racing ones for this car. Can any one point me to the right direction or do i need to special order this bearings? any ideas? would love to have the car running by mid august if not earlier
    Gonna stick with NA all motor but i would love to add a supercharger now that would sound and perform well.
  9. #59
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    I don't think they make crank bearing for the A20, only con. rod bearings, but you might want to give them a call. Why not use honda ones?
    1989 Honda Accord LX-I 300K+
    Build Thread
  10. #60
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    B series bearings?
    -Gio
    My E85 Turbo Build
    5280FEST
  11. #61
    Oct 2009
    Quote Originally Posted by obdriver6 View Post
    ive seen some on this website not sure if it was ACL homepage. If i can't find anything for the crank i guess ill use the honda bearings which will be pricey but i will give them a call.
    B series bearings?
    huh? for a A20 Block?
  12. #62
    Quote Originally Posted by ShyBoyCA6 View Post
    If the B-series rods fit the bearings should fit too
    Nov 2008
    Las Vegas, NV
    ACL makes connecting rod bearings for the A20 but he's looking for crank bearing.
    Build Thread
  14. #64
    cygnus x-1's Avatar
    Chicago area
    I used Toga bearings from these guys:
    http://www.importperformanceparts.net/
    MBH20-HP, and RBH15-HP
    They appeared to be good quality parts and fit perfectly.
    C|
  15. #65
    Nov 2002
    Ridin Dirty in New York
    i used king bearings. Its tough to say if those new pistons you have will work with that block yet because those bores look rough. The crank looks fine but i would at least put in new arp rod bolts if youre going to reuse the rods, but you MUST get the big end re sized if you do this also. Its def worth doing as these are the most stressed fastener in the ENTIRE ENGINE.
  16. #66
    Oct 2009
    Quote Originally Posted by cygnus x-1 View Post
    C|
    ok thanks ill looking into it.
    Thanks for the tip .
    Also i checked the other pistons that came in the mail and noticed something i didn't like.
    I dont know how this passed inspection or if it even passes but it looks horrible. look at the other pic for "PJO and Arrow"
    What do you guys think? would it effect any thing? its carved pretty deep and looks like it might crack after break in or certain mileage. I already called them but the guy that took my order isn't there today. i will call him tomorrow for new replacements.
  17. #67
    cygnus x-1's Avatar
    Chicago area
    It does look bad but I don't think it would cause any problems. How many are like that?
    C|
  18. #68
    Oct 2009
    C|
    2 of them
  19. #69
    Oct 2009
    Called the guy up and he said they dont keep track on the inventory and seNd them out as is but will replace them. So i ask if the piston will work like it should without problem and yes it should. So thats good enough for me so the block will be going to the shop to get worked on. Mean while ill be buying the gaskets and bearings.
  20. #70
    Nov 2002
    Shouldnt be a problem but I like to sand down the rough edges on piston crowns specifically around the valve reliefs. I do it by hand with like 400-500 grit just to eliminate hot spots and stress risers. If this is not gonna be a performance build I wouldnt worry about it or the PJO or arrow marks. Also, the fit of the bearing is more critical than the brand. Any reputable bearing company will be fine. Remember when the oil pressure is good then the engine parts ride on a film of oil, not the bearing directly, so I wouldnt sweat it, as long as they fit within tolerance.
  21. #71
    LX User elpuma's Avatar
    May 2009
    88 Honda Accord lxi
    Grants Pass/Corvallis
    any updates??
    I/H/E, B16 mani, delta 272, OBD1....etc
  22. #72
    Oct 2009
    Sorry no updates at the time. But will have some soon.
  23. #73
    Oct 2009
    i wont't be going down this route for now cause my mom (yes mom) is helping me to get the car running. so im limited to $500 or so on getting it fixed. i already ordered everything for the bottom end and will be installing everything myself. Engine block and head will be in the shop getting cleaned and inspected. only thing im not doing is the head ill be leaving that to the shop to do.
    But i do need help on sealant for the head gasket and intake manifold gasket...im not sure if sealant is required for the exhaust or not. maybe a thin layer.
    Ok so my question is what sealant should i use or what do you use and highly recommend? I got permatex Ultra black for the oil pan gasket cause we used it before and was pleased that it didn't leak or anything. i seen some of you guys use some colored sealant like red or blue. any information would be great!
    Im expecting my car to be done sometime next week and running like a champ that she is.
    On the side note: I do have a Spare head i can mess around with so don't worry about me losing interest on getting the build. block will be to spec but head will take awhile to get the power.
  24. #74
    A Mile High.
    You're kidding, right?
    -Gio
    My E85 Turbo Build
    5280FEST
  25. #75
    dont use any sealant.
  1. Rhonda's New Look...Possibilities
    By ShyBoyCA6 in forum Interior & Exterior Care
    Last Post: 06-05-2011, 09:08 PM
  2. What to build in a rebuilt engine
    By w261w261 in forum 3geez Accords
    Last Post: 11-29-2010, 10:29 PM
  3. engine build b18c
    By levon2008 in forum Performance
    Last Post: 09-11-2008, 05:10 PM
  4. Possible ENgine build idea
    By DDRaptor in forum Carburetor Tech
    Last Post: 12-31-2006, 02:14 PM
  5. Rhonda the Honda....
    By Deadhead in forum Classic Honda Community Chat
    Last Post: 10-20-2005, 06:02 AM
