In quest of getting MOAR LOW, I had this idea of extending my top hat to get the precious shock travel. I wonder if this gonna work. Mad mspaint diagram speaks over 9000 words
Basically, I'll get a new plate welded on top of the stock top hat, drill a new hole to get the strut to go through, and uhh put everything back together again. I probably would gain another 1" of shock travel, and I wonder if this gonna work or even worth it?
edit: I'm gonna have to get the old piece where the strut bolts to as it has this shape to prevent the shock from spinning as you tighten them welded on top instead. Hard to explain but I've got that covered.
edit 2: hood clearance is fine, theres like few mm left too lmao
