Symptom: Compressor will not engage, switch lights up and blower switch works.
Checked all fuses, not just visually, with a meter, went through diagnostics and the fan motors come on when connecting the Bu wire at the diode to ground, compressor engages when connection diode Bu/R wire. FSM says I have a open in the Bu/R wire.
I also show open at the switch connector Bu/R wire and at the Delay Control Unit R/Bu wire.
Diodes and relays all test good. The cooling fan relay connections in the under hood fuse box are a little strange though. I get 12v through the 1-2 circuit but I have no voltage on either side of the 3-4 circuit that should get switched when power is applied to 1-2. Seems like I am not getting power to the circuit I can't find the open and I am running out of places to look. There has been no aftermarket goodies added, there have been no splices or hack wiring done to the car and everything else electrical works like a champ. Anybody have any ideas where to look next?
