Results 1 to 13 of 13
Thread: "FUEL" light problem
    DX User 1stgen!!!'s Avatar
    Jan 2011
    79 Accord sedan SJ5
    Brazil
    hey guys
    i'm having alittle problem with my reserve fuel light, it never turns off!
    what is going on with my fuel float?
    thanks for any help
    Re: "FUEL" light problem
    Mine never works haha but is your fuel gauge working fine?
    Jan 2011
    79 Accord sedan SJ5
    Brazil
    sometimes when fill up the tank, he marks empty...then suddenly it returns to working...
    DX User reYmo's Avatar
    Jun 2011
    1st gen Accord , 1980
    Indonesia
    as far as I know, there is a separate device for fuel light, which embedded to fuel float.
    or, there is another small float attached to fuel float.
    that little float must be stuck, take them out of your fuel tank to inspect.
    sometimes a little knock-knock at the fuel tank solve it.
    LX User 1GCustomAccord's Avatar
    Jun 2008
    79´Accord,83´Lude,71´Nova coupe,83´Pontiac 6000,69 Mustang coupe,and many more rusted crap...
    PY
    Before changing the thermistor or complete sending unit you first need to check the system. Test the low fuel lamp by grounding the thermistor wire under the back seat with the key in ignition, (i think is a green/red wire) if the lamp lights up, the thermistor is bad, if not, the lamp is burnt or the wire is broken somewhere.
    The sending unit in the fuel tank is in fact 2 devices, a float with a resistor attached, and a THERMISTOR (basically a resistor in a bullet-shaped case) for the low fuel light.
    The working principle of a thermistor is temperature: When the fuel is high, the thermistor is submerged and is cold, having very high resistance (around 1500 ohms @ 25 celsius) so no current flow. When the fuel gets low enough, the thermister is not submerged in fuel and the temperature rises, so resistance drops, so current flows, so lamp lights up, so you go to the nearest gas station.
    So many reasons why
    I won't be sending postcards
    From Paraguay
    Woot thanks for the info! I never bothered to check why its not working before haha.
    Jun 2011
    Indonesia
    Quote Originally Posted by 1GCustomAccord View Post
    Genius!!
    I never check mine also....maybe because I never run out of fuel. but since I had this car, that light NEVER goes on...
    Thanks for the info!!
    Jan 2011
    79 Accord sedan SJ5
    Brazil
    life is funny someguys never seen the light on
    and i always see mine on... at night that strong red light ,that haven't dim function, obfuscates me...
    Jun 2008
    PY
    Welcome guys!
    So many reasons why
    From Paraguay
    So I've decided to drop the tank and see whats up with my FUEL light not coming on even after I've drained the tank.
    The thermistor broke into pieces ><
    Does anybody know if a regular thermistor would work as a replacement?
    Screw fixing the original sensor! I tried everything I could to replace the thermistor with stuffs that I have lying around and it still wouldn't work.
    I've decided to built another circuit to work off the float level, turning on the lamp around < 8 liters left, just like how the stock system works.
    PICS and HOW TO!
    No that circuit doesn't work -.-
    It won't go off even when the tank is full. Well when I had the sensor shorted so the gauge would read full haaah!
    Now back to finding another circuit that would work.
  1. Classic "Taxi". Good ole Jim. "What does the yellow light mean?".
    By Bluntman in forum Classic Honda Community Chat
    Last Post: 06-28-2012, 12:21 PM
  2. How to turn the "dead tail light" light off...
    By charliekuney in forum 3geez Accords
    Last Post: 12-20-2009, 05:03 PM
  3. Replies: 1
    Last Post: 04-18-2009, 01:41 AM
  4. Replies: 12
    Last Post: 10-01-2002, 05:15 AM
