There were 2 versions of the B20A
The first generation of B20A engines was available in the 86-87 Prelude 2.0SI in Japan and Europe, the 86-89 Honda Vigor and Accord . It leaned towards the front of the car just like the A20A engine found in the same cars. This B20A produces 160 hp (119 kW) and 140 lb·ft (190 N·m) torque in Japan. In Europe this called B20A1, produces 137 hp (102 kW) and 127 lb.ft (172 Nm).
There was also a similar engine named B18A for the 86-89 Accords. It was a destroked B20A powered by 2 Sidedraft Keihin carbs.
The second generation of B20A was found in the 88-91 Prelude. The 88-91 Prelude B20A and B21A blocks are cast so they lay at an 18-degree angle leaning towards the firewall. This was done to please the exterior specifications for the 1988-1991 3rd Generation Prelude due to its ultra-low hoodline which Honda dubs the "engineless design" and also for handling reasons due to placing the engine at an angle gives it a lower center of gravity (similar to straight 6 designs in older BMW's).
