Page 7 of 8 FirstFirst ... 345678 LastLast
Results 151 to 175 of 179
Thread: MessyHonda's B swap
  1. #151
    Re: MessyHonda's B swap
    I moved to a new place in July and got internet installed about a month ago. I like my new place its a in law unit in the back of the main house right next to a 2 car garage. I had to clean up the garage to even get my car to fit. Today was my tune up day. Replaced the oil, tire rotation, new cam seal, valve cover gasket, vtec solenoid and low profile washers. I had them since April and just collecting dust. ok enough talking and now for pictures.
    Here is the plain and boring engine bay. Its a daily driver so keeping it clean has fell sideways.
    Under the valve cover
    Taking off the cam seal cap
    Installed Skunk2 Cam seal and Vtec solenoid.
    Installing new OEM spark plug grommets on the new Valve cover.
    here is the final product. Now that my leak has stopped I will get my engine steam cleaned.
    hope I will be around more and thank 2oodoor!
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Nice tune up man! Glad you got that VC painted too because it was looking pretty haggard.
    What will the Skunk solenoid do?
    Andrew.
  3. #153
    The skunk2 Solenoid is just billet and it cleans up the engine bay a bit. Wanted to replace the oil seal and vtec screen. Engine feels alot smoother but it needs more power now.
    Huge improvement! Keep up the good work.
  5. #155
    Very nice. You know what you need? a Coil on plug conversion boss. Anyway looking great
    Thanks Josh. I remember when I joined I looked up to you guys. Im planing on picking up Hondata S300 with the coil on plug set up but I first need to install my wiring harness.
    I also picked up a new half size radiator. Its time for me to start getting it ready for a turbo set up.
    boost or die!
  8. #158
    Very True jessy. You can get the what i got for only 350 an plugs to your stock ecu. idk i cant see my self forking out 1000 bucks for a ecu an other 500 for the coil on plug add on. you get the same results plus B series use Honda fit coils perfectly. Which is what im using which im sure you know that.
    To make it little bit cleaner i just added the cover. Took me couple hrs to run the harness (pre made) to ecu an tap a few wires an wala done. hondarulez sells it complete kit with coils for 350. oem coils as well. I think its a steal.
    anyway dont want to jack your thread just giving you other option .
    looks very clean and a good deal. Im going to turbo so this is why I want to go with Hondata. I should just pick it up to run NA for now but i still need to stall some of my bolt on. I need to install my 70mm skunk2 TB and going to upgrade to 3 inch exhaust. I first need to pick up a daily because I use my car every day so i can only do day or weekend projects. Richard and I are working on getting a Traction bar with one of his boy that works at a welding shop.
    Gotcha. I mean its a steal in my book love how i just crank it an fires right up even on a super cold day
    Update: 09/10/2016
    Hey guys,
    I've been busy with work and life. The accord clutch cable decided to snap in June. They had it in stock at the part store and I replaced it in the parking lot. In July I moved back to San Mateo and now i'm putting more miles on it. Raced a automatic G35 with intake and exhaust and I smoked it. After getting off the freeway I noticed that my car would not go in gear. I would have to turn it off and start in gear. I had a Stage 4 clutch since last year so all I had to do is pick up a aluminum flywheel to install. I also installed my MFactory LSD with new carbon synchros and bearings. It shifts very smooth and now its a bit firm on gears. The clutch is a bit heavy but its ok as long as I'm not in traffic. I have put 500 miles since the LSD install and its so werid that in turns the car just wants to turn and its nice to have power in both wheels. I have already pushed my car around the twisties and I ended up 180*. Now I know I need a traction bar since my accord one keeps on breaking. Its the 3rd time in the last 2 years. I will keep you guys updated with more since I will be taking it to JCCS 2016.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I love this build. Keep up the good work. You'll get everything right soon
  13. #163
    No pics?!
  14. #164
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Will be working on photos soon.
    Sent from my SM-N920P using Tapatalk
  15. #165
    pics are going to have to wait till JCCS
    my broken clutch cable that was replaced with 1993 acura integra gsr clutch cable
    my 70mm skunk2 TB installed with thermal intake and throttle body.
    relocated the batt to the trunk.(no pics)
    the goodies
    Feb 2012
    89/accord/lxi
    Nice work bro. FYI photo shoot will happen very soon everyone.
  18. #168
    it was time to upgrade to a 350mm wheel since my 320 was a bit small and would not let me see my cluster. got a momo and wow what a day and night difference. looks an feels good to drive the car. its a quality wheel and you can just tell by the build.
    Feb 2016
    Florida
    Awesome update
  20. #170
    Nice! A nice wheel makes all the difference!
  21. #171
    wow cant believe its been a year since I did that work. Since I already posted on facebook I will post the pics.
    Feb 2016
    Florida
    I see you got your half size radiator inn looks good .looks like you didn't have to modify anything
  23. #173
    thats such awesome progress. Im still pretty jealous even if i do have a worked b20a myself. not as many cool parts
  24. #174
    Thats what I want you to think. Both bottom radiator mounts had to be welded in the bottom and the top stud of the radiator had to be relocated but the hoses fit just perfect. I'm glad I went with this set up to make room for a big turbo kit and way to mount a rear mount intercooler.
    Feb 2016
    Florida
    Looks clean. good work
  1. my old 88 messyhonda dx
    By MessyHonda in forum Classic Honda Pics & Videos
    Last Post: 04-28-2010, 03:02 PM
  2. MessyHonda's updated PhotoShoot
    Last Post: 10-10-2007, 12:50 PM
  3. MessyHonda is one LUCKY....
    Last Post: 10-02-2007, 07:07 AM
  4. MessyHonda's Teg CAI
    By MessyHonda in forum Performance
    Last Post: 08-03-2007, 10:39 PM
  5. MessyHonda's fast wax and pics
    Last Post: 10-25-2006, 10:12 PM
