Results 1 to 12 of 12
Thread: Prelude brakes
    Jul 2011
    1987 LX Accord (dd & love), 91 CRX DX (sold), 89 240SX (toy)
    Yuma, AZ
    Prelude brakes
    I know you can use SE-i rear brakes to convert to disk from drums but are you able to use prelude to just bolt on?
    Duck Hunter
    1987 Accord LX Sedan
    cygnus x-1's Avatar
    Chicago area
    Re: Prelude brakes
    Quote Originally Posted by 87lumper View Post
    If you mean the Prelude rear discs, then no. You need the SE-i knuckles as well as the calipers and rotors. The 3g Accord front rotors are actually the same as the 3g Prelude front rotors.
    C|
    Ichiban's Avatar
    North of You.
    Re: Prelude brakes
    2g prelude rear discs actually bolt to 2g accords. Thought you might like to know.
    ICHIBAN!
    "Now, even more better!"
    cygnus x-1's Avatar
    Chicago area
    Re: Prelude brakes
    Quote Originally Posted by Ichiban View Post
    That's interesting, because it means that my 2/3g Integra hub adapters should work on the 2g Accords as well. I wonder if there's a way to bolt up the calipers then?
    C|
    Re: Prelude brakes
    What are these hub adapters? Is that so you can run a rotor-over-hub type setup?
    cygnus x-1's Avatar
    Chicago area
    Re: Prelude brakes
    Exactly. There's a member on PP that races an '86 'lude, and he was having problems with breaking the rear hub/rotor. We decided that the only available aftermarket rotors were not up to the task of racing, so I came up with an adapter sleeve to allow bolting an Integra hub and rotor onto the Prelude spindles. The Integra rotors are the same diameter and nearly the same offset as the 'lude rotors, so the only modification required for the brakes is to add some washers between the caliper bracket and mounting plate. I don't know how many races he's done since the conversion but he hasn't broken anymore hubs.
    And as an added benefit, the rotors can be replaced without having to mess with the hub.
    C|
    Jul 2011
    Yuma, AZ
    Re: Prelude brakes
    What should I do if I can't find an se-i is there any other way?
    Duck Hunter
    cygnus x-1's Avatar
    Chicago area
    Re: Prelude brakes
    Depends on what lengths you are willing to go to. 2/3g Integra rotors will fit the rear hubs directly. Mostly all you need is somewhere to bolt the calipers to. I'm not that familiar with the Accord rear knuckles but I just made some adapter plates to fit other calipers on my 2g Prelude, so I imagine it would be possible to do something similar with the 3g Accord. If somebody wants to send me a junk rear knuckle I would be happy to look into it.
    C|
    Jul 2011
    Yuma, AZ
    Re: Prelude brakes
    If only I was up there haha. But let me know if you find anything out thanks.
    Duck Hunter
    Ichiban's Avatar
    North of You.
    Re: Prelude brakes
    Quote Originally Posted by cygnus x-1 View Post
    C|
    The caliper bracket isn't sandwiched with the backing plate mounting like the prelude was?
    ICHIBAN!
    cygnus x-1's Avatar
    Chicago area
    Re: Prelude brakes
    I really don't know. Anyone have a picture of the 3g rear brakes with the rotor and hub removed? I should just search.
    C|
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Prelude brakes
    the hub must be removed to remove the dust shield/ backing plate on the rear disc models. it is attached with 3 or 4 phillips head screws. The caliper bracket IIRC is not sandwiched with the backing plate
    3Geez resident body man
    Owner of Wreck-less auto body
  1. prelude rear disk brakes
    By VIPER1988 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-09-2010, 03:26 PM
  2. Big Brakes and Addco rear sway bar on sei brakes
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 10-01-2007, 01:13 PM
  3. Switching carb brakes to EFi brakes...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-21-2005, 04:09 PM
  4. brakes.... my kingdom for new brakes
    By 89accord_lxi_coupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-02-2003, 04:11 AM
