Results 1 to 11 of 11
Thread: Should I keep her? (Image Heavy)
    DX User JamesJimJam's Avatar
    Feb 2011
    1989 Honda Accord LX-I
    Nebraska
    This is my '89 LXi Sedan, Rhonda. She is in good mechanical condition, and the interior just needs a bit of work. The body, on the other hand, is in rough shape. It has a few dings, but rust is the main problem. Below are pictures of the problems with her body.
    Feb 2011
    Nebraska
    Re: Should I keep her?
    The question:
    What should I do with her? I definitly want a 3gee, but there's not many in good condition in this area.
    HALP MEH.
    Re: Should I keep her? (Image Heavy)
    I would say find a new shell that is rust free. Maybe one with a dead motor or something that you can get for cheap, and swap all your good stuff into it. That body will be a nightmare to repair unless you are super hardcore.
    LXi User Ayeobe's Avatar
    Aug 2008
    1989 Honda Accord EX-i AT
    Montreal, QC
    The fenders are just aestetic. What are the undeside, or rocker panels like?
    The key points: Front bumper mounts, rear bumper mounts, the floor, the rocker panels, the inside of the trunk, the front wheel-wells specifically around the shock towers. Also, the spot where the front controll arms meet the body, even mine has rust there.. If those are solid, i'd fix the fenders and rustproof that shit. Also, have you done the gas-tank door recall?
    170 156.5km | 12 348.6km
    Feb 2011
    Nebraska
    Quote Originally Posted by Ayeobe View Post
    Underside is mostly okay, with a small rust spot under the driver's footwell from something that spilled, I'm assuming.
    And no, what is the gas door recall?
    There was no gas tank door recall, at least here in the states. All we got was the front seat belt latches. Also, that car isn't bad except for the rust. Everything else can be fixed easily and with little time, but the rust cannot, so I agree with what 2ndGenGuy says.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    it was for the gas filler pipe... they would rust out.
    it's a metal piece that is supposed to strengthen the area around the filler neck, it was very much here in the states, even my car had one, although no rust, i ended up removing it, as it caused problems with the gas door closing. it looks like it was supposed to fit BEHIND the rusted out area, maby weld in, but Honda somehow got away with bolting it in from the front, probably so they didn't have to remove the tank for welding, when it's fit from the front, it changes the geometry of the door hinge, and the door doesn't work quite right. If I had a rusted out gas filler area like you do, I would drop the tank, cut off most of the area and weld in the recall part, it's made of heavy gauge steel and would make a permanent repair
    That's hella weird because I've checked into recalls for both 1988's and 1989's and this has never come up.
    Also: Why does everyone name their Honda "Rhonda"? haha
    it's there, i've got one
    I put a post up, but this is another recall i've never heard of, involving the fuel filler neck itself, this one came out in the early 90's involving our cars
    http://auto-recalls.justia.com/honda...986/92v028001/
  1. sunroof leaking under heavy rain
    By wolgerine in forum 3geez Accords
    Last Post: 09-21-2010, 07:35 AM
  2. Never seen my 3gee under heavy snow
    By skong in forum Classic Honda Pics & Videos
    Last Post: 05-17-2010, 10:52 PM
  3. Heavy Rain leaky car
    By LewZur in forum Classic Honda Community Chat
    Last Post: 01-20-2010, 02:07 PM
  4. bilstein heavy duty shock
    By doug in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-26-2002, 02:20 AM
  5. Heavy ass rims, need lighter ones!!
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-13-2002, 05:58 AM
