Results 1 to 11 of 11
Thread: had to move the s2000 start button
    I had it all mocked up on my new dash on my bench, I was going to mount the start button where the cigarette lighter used to go, but when checking clearance on the old dash,still in the car, I discovered it won't fit there with the center console, figures. after a lot of deciding and staring at the dash, I decided to mount it next to my gauges in the upper part of the dash, I had already made a really nice aluminum bezel the switch snaps into, so I wanted to use that over. I ended up making this piece, It started off as part of an old nose gear fork off of one of our planes, This would have been the part the axle went through, After a bunch of machine work, I got this.
    let me crank of some 80's hair band rock and I'll get started
    I had already used an end mill to make the counter bored areas for the screws,
    you can see i built in some adjustment to align the center bezel
    the next step is to center punch each counter bore on center, I like to use a carbide scribe for precision center punching, then center punch with a regular punch
    next the holes are drilled for the screws
    the entire bezel is screwed to the dash
    and the center is drilled with a hole saw
    and the switch,this is a real one not a knockoff
    I'm painting the bezel black right now, to match the gauges, the aluminum trim ring around the button will stay polished
    DX User Warren 88 Accord's Avatar
    Feb 2011
    88 Accord LX-i
    So*Cal San Bernardino
    Re: had to move the s2000 start button
    that looks awsome
    Quote Originally Posted by w261w261 View Post
    I get 47 mpg with power shifts, a/c blowing, 6k shifting, and a little lying.
    Quote Originally Posted by Warren 88 Accord View Post
    that looks awsome
    thanks, the letters on the button are straight of course, i just popped it in there a little off center to take the picture
    May 2011
    1989 Accord Lxi Hatchback
    Antelope Valley, CA
    Love the 80s selection you had on.
    I need to probably repaint both this piece and the gauge panel, as it's been so many years, I couldn't remember what type of black I used. I also need to grind just a little more on the back of the piece to fit the bottom curve of the dash, not a big deal
    Looks pretty good Lost!
    Ok I stripped the paint AGAIN, somehow the paint reacted to the primer and flaked, I'm trying something new, it's called dual by krylon I'm happy with the results so far, the only drawback is it's 25 minutes before you can handle the part, and 2 hours before it's dry.
    the warning lights are old school bulls eye lenses, I recessed them into the back of the gauge panel, i'll use high brightness LEDS in the backs of them, one lamp for the voltage and one for the oil pressure, I'm thinking of something in the bottom section for a shift light, but it's just an idea right now.
    carotman's Avatar
    Montreal South Shore
    Looks nice!!
    I wonder if you could match the button bezel curves to match the other gauges.
    I need these parts!
    Looks nice!!
    /img]
    I might round these two corners off slightly, but it would be too much of a pain in the ass to try to duplicate another from scratch. I think if I rounded the two corners it might flow better with the gauges.
    The LEDS for the warning lamps are in, instead of making housings, I used part of the original lamp housings, these are old Amphenol machine indicator lamps, they are a standard size lamp and very common. the part with the bulb and the contacts can be removed from the housing, all you have to do is press two tabs. the LEDS were a perfect fit, I used Radio Shack part number 276-0005, ultra high brightness 10mm white LEDS, I used 14 volts as the voltage, the LEDS have a forward current of 20 ma, and a forward supply voltage of 3.5 volts, this gives me a required resistor value of 560 ohms, using a half watt resistor. it calculates out to a common resistor value using 14 volts, a lot of people use 12, forgetting the operating voltage of the electrical system is closer to 14.
    I used epoxy as a potting agent to hold the LEDS in the bulb housings.
    this stuff is great, it sets in five minutes and comes with mixing tubes
    I picked these lamps because they have an old school bulls eye lens
    they don't even look like LEDS when on
    I was very surprised at the quality of the light from these LEDS, they were just over 2 bucks each. I'll be using them in more places in the car
    I ended up replacing the standard bulbs with LEDs, I used the same ones as the indicators
  1. losts s2000 pushbutton start switch project
    By lostforawhile in forum Project Central
    Last Post: 03-12-2011, 11:06 PM
  2. s2000 start switch
    Last Post: 05-09-2010, 08:00 AM
  3. Start Button a'la S2000 (With how-to)
    By Sabz5150 in forum Interior & Exterior Care
    Last Post: 06-24-2005, 11:58 AM
  4. questions about the start button (like s2000)
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 12-08-2003, 09:45 PM
  5. [Electrical] Install a start button (like the S2000)
    By Sabz5150 in forum How To
    Last Post: 05-07-2003, 09:34 AM
