Overheated engine repair project completed. (Replaced blown head gasket, cylinder head resurface and valve job.)
First tank of gas netted 31.25 MPG. That's driving around Athens, GA making my service calls.
Things I’ve done so far that should help MPG:
Valves adjusted meticulously.
Fresh spark plugs gapped at 1.1 mm
New air filter
10w 30 full synthetic oil
Timing set at 22 degrees. Had to back off 2 degrees from the 24 degree spec due to spark knock.
Vacuum advance replaced and rerouted vacuum lines for part throttle vacuum signal at all times.
EGR disconnected. (No part throttle spark knock)
Carb cleaned and ran Berryman carb cleaner through the tank. (Idle mixture screw still sealed. Running at little lean at idle right now.)
Tires at 40 PSI
Cruise control used whenever possible.
No extra weight in the trunk.
Rain X ed windshield. ;-)
Any other suggestions for low buck MPG improvement?
