Okay, So I hesitantly allowed a friend to Sea Foam my 81 Accord... You know, flow some seafoam through the manifold via a vac line. Surprisingly once the smoke cleared, it ran great for about a week. Then, while driving to work, it stalled. Only way it would start was to floor it. Once started it ran okay, later that day it would only start with the gas floored. Even when driving, if i let off the gas to shift gears, it would die. I drove it home when I got home I noticed the Catalytic Converter was glowing red. I assumed bad cat. I have dropped the cat, and even with the cat removed it still wont run the same, still need to floor it. So I figure it's the carb. I would swap to a Weber, but I can't, I need to pass emissions. Okay guru's.. Save my ass... again....
