After sitting for a while, my '86 Carb Accord just started to hesitate and misfire if I suddenly press the gas pedal between 1000 - 3000 RPM. It does not want to accelerate. Sometimes at idle if I press the gas pedal suddenly again it puffs smoke from the carb and it dies. Any ideas? Feels like not enough air b/c of the puffs (I think it is due to unburned gas)
If driven normally it is OK. Let say I知 in 5th gear 2000 RPM if I press the gas suddenly it start to cough/hesitate. I have to let the gas pedal and press it again more gentle.
I checked the ventury, vacuums, sensors, oil, coolant, PVC, filters you name it. Even opened the top hat of the Carb., acceleration pump is OK, power valve is OK, clean inside the Carb. chamber.
Idles OK, just when you give her more gas it does not want to raise the RPM it hesitate and in most cases it dies with a misfire and smoke coming from the Carb.
I'm sure I知 missing something. Any suggestions?
Also it starts/cranks hard
