Results 1 to 6 of 6
Thread: Seriously Confused
    LX User fmn716's Avatar
    Dec 2009
    3G Accord CA3
    South Africa
    Seriously Confused
    Hi Gents
    I am gathering parts for my brake upgrade
    and I have JDM twin piston brakes I have read though some articles which I have learnt that the pad size is the same as the base model, so why would you use a smaller 2 pot caliper that a bigger single pot one ?
    I want to upgrade this as I want to use 11" rotors with a custom bracket
    Thanks
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Seriously Confused
    Twin piston calipers have more clamping force. On some vehicles, the better brakes are the smaller twin piston calipers. Heck, in racing, you only need to have enough braking power to make your wheels lock up. Anything more than that is just wasted potential.
    cygnus x-1's Avatar
    Chicago area
    The clamping force is determined by the cross sectional area of the pistons. You can find that with this equation:
    r * r * 3.14
    where r = piston diameter divided by 2. For multiple pistons you just add the areas of each piston together. The single pot ITR calipers have an area of 2551 square mm (57mm piston diameter). I actually thought the Honda 2 pots had a slightly smaller area than the ITRs but I could be wrong there.
    The 2 pots will have more even pad wear because more of the pad is supported by the pistons.
    C|
    Dec 2009
    3G Accord CA3
    South Africa
    ok cool for the answers guys but I have been searching but I am not sure if this is correct does the accord use the same brake pads as the usdm si sohc ?
    cygnus x-1's Avatar
    Chicago area
    Quote Originally Posted by fmn716 View Post
    Yes and no. The 2g SI Prelude (USDM) uses the same pads as all of the 3g Accords (USDM), EXCEPT the '88-'89 LX-i and SE-i. The '88-'89 LX-i and SE-i use larger pads that are the same as the 2g Integra.
    C|
    Brake pads have a "D" prefix somewhere in there part number. So the ITR are D503. I think the Lxi are D409. Might help you figure out what pad goes on what car.
    http://www.fmsi.org/home
  1. ok i still confused...
    By BKKloppenborg in forum Performance
    Last Post: 05-05-2004, 08:09 PM
  2. Confused
    By Brentm in forum Classic Honda Community Chat
    Last Post: 01-26-2004, 10:16 AM
  3. Confused!
    By 98hp in forum Classic Honda Community Chat
    Last Post: 11-25-2003, 08:30 PM
  4. i'm confused
    By 89accord_lxi_coupe in forum Classic Honda Community Chat
    Last Post: 08-08-2003, 03:21 PM
