Results 1 to 19 of 19
Thread: Am I missing a belt?
    My car was making a weird noise, so I sprayed some belt conditioner on all* of the belts (*that were there), and the noise stopped...but I realized that there is a belt completely missing from my engine, and honestly, I don't know how long it's been gone. There is an identically sized gear/spline that is closer to the front of the car, under the alternator? Pictures:
    Re: Am I missing a belt?
    AC belt
    Do I have to have it? Would pushing the air conditioning button without a belt be a bad idea?
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    nah, just wont do anything...
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    on a side note charlie, what happened? you used to post 350 things a day, then you are gone for a while, then come back askin some day 1 questions........?
    Jan 2010
    86' Accord Lxi
    I cut mine off since the A/C didn't work and I hardly use it anyway, less drag on the motor
    1986 Accord Lxi- Auto,Blue,155k
    there wouldn't be any point as there is nothing to drive the compressor it would just sit there
    Quote Originally Posted by headley View Post
    hi friend !
    I have clicked the link which you have given on the page.
    thank u for the posting
    Tour Package
    reported
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    hi friend !
    Thank u for the posting
    tour package
    shpam!
    shpam!
    and he's spamming more right now
    Another thing is: my air conditioning still works...somewhat. It's not ice-cold, but it definitely does not blow hot air, even in the summer.
    if you have a belt on your power steering pump,and a belt on the water pump and alternator, then your AC DOESN'T WORK, it needs the belt to be hooked up to do anything
    I looked at the pictures again and you don't have ac in any form anymore,I see a power steering belt and an alternator belt
    ...yet when I push that air conditioning button, cold air blows. Normal cold air, I guess? How hard is it to replace the belt?
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Good eyesight!
    There is no compressor pulley down there, only the crank pulley...
    Good eyesight!
    um the groove for the AC belt is whats open, alternator water pump is on the inside, ac belt is in the middle, and the PS belt is on the outside on the smallest groove
    My air conditioning compressor is there, you just can't see it from the angles of the photos.
    Why is everone so concerned about seeing the compressor? You can see the belt missing on the crank pulley
    I don't know, but thank you so much for your help! (:
  1. Bad MPG. What else am I missing?
    By Hazwan in forum 1geez Tech & Performance
    Last Post: 10-26-2012, 02:33 PM
  2. Missing Still
    By Bigg_Billy in forum 3geez Accords
    Last Post: 05-09-2005, 10:17 AM
  3. Missing
    Last Post: 05-05-2005, 03:27 AM
  4. Missing
    By Janiel in forum EFI Tech
    Last Post: 05-13-2003, 08:29 AM
  5. Missing when first starts
    By somedrummerguy in forum 3geez Accords
    Last Post: 02-10-2003, 07:37 PM
