Results 1 to 10 of 10
Thread: 86 manual accord wont start. please help!!!
    Sep 2011
    Exclamation 86 manual accord wont start. please help!!!
    so, i have this 86 honda accord that wont start. about a year ago it had an issue dieing. put gas in it, it ran for 2-3 miles, then quit again. parked it, up until now, because i have a nephew that needs it. now the timing spot on, i have spark, and fuel is making it all the way through. any idea what else may be wrong??
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: 86 manual accord wont start. please help!!!
    Quote Originally Posted by nightsoldier22 View Post
    carbed or fuel injected?
    2011 Is going to be my year to do it or give it up!
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    We need more details to diagnose your problem.
    Sep 2011
    carb. what other info u need to know?
    Can you give a better description of what is happening? Dying at lights? While driving down the road? After it runs out of gas? While you are drifting at 9,000 rpms?
    Sep 2011
    Car wont start. Has good spark, gas up to the carb, wont fire on ether, appears to be a timing issue. Timing belt looks brand new.
    Original happenings that started this all: Driving on interstate, car died, 1/4 tank of gas. thought gas gauge was stuck so added 5 gallons, car started right up, drove 2-3 miles and it died. Pulled it home, never looked at it until the other day. It fired once immediately after first turn of the key but not again.
    Almost sounds like a bad ICM. I don't really know how to diagnose those though. Had you had sporadic losses of power before the freeway incident?
    89T's Avatar
    Apr 2004
    It almost sounds like a fuel filter.
    un-motivated!
    3GR
    Shoot a little bit of starting fluid down the carb. If it tries to start you will know you have a fuel issue. If nothing happens you have an ignition or timing issue
    Go from there.
    Eric
    Feb 2004
    1988 LX Sedan
    East TN
    If you are getting gas and spark, I would do a compression check on the cylinders to make sure compression is good. Also, check that the firing order is correct. The numbers are usually on the distributor cap and cyl #1 is closest to the driver's side on US cars.
  1. 87 accord wont start
    By Civic Accord Honda in forum Carburetor Tech
    Last Post: 12-29-2007, 11:47 PM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. 87 accord lx wont start help
    By g0ldfinGa in forum Classic Honda Community Chat
    Last Post: 03-02-2004, 11:38 PM
  4. accord wont start now.
    By Festo in forum 3geez Accords
    Last Post: 11-18-2003, 08:12 PM
  5. My Accord wont start
    By Fusion1976 in forum Classic Honda Community Chat
    Last Post: 10-04-2003, 09:29 PM
