I can't remove the bezel off the speedo, i got the top part undone but I'm having issues trying to get the bottom part loose, are there any other screws holding the belzel in place?
pull the switches out and you'll see the other screws, then after everything is undone, you have to reach behind the cluster and push the clip to disconnect the speedo cable
