Results 1 to 7 of 7
Thread: oil in air filter?
    oil in air filter?
    Im guessing this means a blown head gasket? I bought the 88 Accord with 155k on the clock for only $300 so Im not losing too much money, but Im curious if anyone has direct experience replacing the HG? Prior owners thought it was a rear main seal leak, but Im not finding enough oil in that area to support that. Instead, as I began prying off parts and inspecting, I noticed the air filter itself was soaked with oil in the bottom third. To get that much oil on the air filter I would think the HG has to be faulty.....
    what do you think guys?
    Nov 2006
    Re: oil in air filter?
    A failed PCV and/or excessive blow by?
    PVC system needs servicing, if you take the oil filler cap off when it is running and you get a lot of smoke then it's maybe some blowby, has to be a good bit though since the PVC sounds to be lax.
    HG would not normally be the first thing to look at on that issue.
    Aug 2007
    1987 Accord Carbed Auto Stock
    Sounds like blow-by. Does it smoke out of the tailpipe? You might try a compression check if it is convenient.
    x3 on PCV.
    oh good! I like that answer. Will attend to that today. thanks guys!
    LOL. You obviously haven't done it yet...
  1. Filter?
    By Jasonf860 in forum Performance
    Last Post: 05-27-2007, 08:44 PM
  2. Air Filter
    By Drucifer in forum 2geez Accords
    Last Post: 12-25-2006, 04:22 PM
  3. can i use this filter?
    By A18A in forum Carburetor Tech
    Last Post: 12-16-2006, 07:02 PM
  4. little filter?
    By dub88acc in forum Classic Honda Community Chat
    Last Post: 02-25-2004, 09:05 PM
  5. Take of air filter
    By 1986hbdx in forum Carburetor Tech
    Last Post: 01-14-2003, 02:44 PM
