Results 1 to 7 of 7
Thread: How do I remove the antenna?
    DX User Clint's Avatar
    Sep 2011
    1989 Honda Accord DX
    Far West Kentucky
    Went by the Pick-A-Part yard today to look at the '89 he has. One if the things I need for my DX is an antenna as mine will not go all the way in being bent a bit. The '89 in the yard had a broken one but I thought I would try to remove it to see what it would take to remove mine. I removed the two screws and thought it would pull out but it is connected some where deep down inside. I am guessing the cable has to be disconnected but how do I gain access to it?
    Thanks
    _________________
    Clint
    Far West Kentucky
    '89 DX
    Fedor B.'s Avatar
    Aug 2010
    '89 Aerodeck EX 2.0i Excusive Edition
    The Netherlands (Holland)
    Re: How do I remove the antenna?
    Best way to get to it, is to remove the fusebox. And even then it's not easy to get to.
    SE-i Sedan 5 spd
    Do some searching on this site. There are posts detailing how to get an old antenna out and a new one in. It's not easy.
    Sep 2011
    Far West Kentucky
    Quote Originally Posted by w261w261 View Post
    I did the search using the Google tool and there are quite a few threads about power antennas. But as far as I can tell the antenna on my DX is manual. The automatic antennas seem to have the motor mounted under the left side of the dash behind the fuse box. Do I have to access the same area to disconnect the cable to my antenna to be able to remove it?
    _________________
    Clint
    Far West Kentucky
    '89 DX
    Fedor B.'s Avatar
    Aug 2010
    Quote Originally Posted by Clint View Post
    In the service manual is nothing about the non automatic antennas, but it looks like the only way.
    For a DX, it's going to be a lot easier. The power antennas are nearly impossible. Here is the best write-up for the power antennas. For the DX, there is no motor to disengage and no plastic push rod to maneuver down the A-pillar. If you are able to find an antenna in good condition, just snip off the plastic push rod from the motor and then you have only the antenna wire to feed down the A-pillar. Be sure to attach a string to the old antenna wire before pulling it out. You will have no way to pull the new one through if you forget that important step.
    It's a Honda, bend it back.
  1. Antenna for LX-i
    By okoka595 in forum Wanted
    Last Post: 02-10-2011, 01:13 PM
  2. Antenna
    By Zt527 in forum Interior & Exterior Care
    Last Post: 08-18-2007, 02:11 PM
  3. how to remove and replace power roof antenna
    By lamontlamont in forum 3geez Accords
    Last Post: 03-07-2006, 11:19 AM
  4. How to remove power antenna?
    By forrest89sei in forum Interior & Exterior Care
    Last Post: 07-21-2005, 10:43 AM
  5. Power antenna v. manual antenna masts
    By offthahook in forum 3geez Accords
    Last Post: 09-08-2002, 03:53 AM
