So I have an 89 accord that when cold idles fast then seems to calm down as it gets hotter I can also remedy the fast idle problem by pumping the gas a couple of times. Problem is when it gets to a certain temperature and I put it into neutral the car wants to die. Sometimes it will bounce between 0 and 1 and some times it just gives up. I thought it might have something to do with the Air temp sensor replaced that and nothing. Checked around today for a vacuum leak found nothing. Some online places have said that the IAC valve might be bad, but I can't seem to find it on my car. If anyone knows where it is let me know I will check that, or if anyone has had this problem and fixed it let me know. I did a search it seemed that someone had a similar problem, but there was no fix. Oh I have replaced distributor, plugs, and wires. If any more info would help I can get that for you. Thanks
